LPC845 port byte write
2,153件の閲覧回数
gschelotto
Any hint to write a port byte GPIO output on LPC845? I'm not able to find it in the SDK examples.
regards,
gaston
2,140件の閲覧回数
gusarambula
Hello Gaston,
The closest example available would be the gpio_led_output, available on the latest SDK, under drivers_examples, which may serve at least as a starting point.
You may import it using the Import SDK example under the Quickstart Panel on MCUXpresso.
My apologies for the inconvenience.
Gustavo
2,141件の閲覧回数
gusarambula
Hello Gaston,
Gustavo
