LPC845,how to use external crystal as the chip clock source?
1,848 次查看
Roger_WANG_2022
I use the LPC845-Example-Code-Bundle-IAR code to test my board. when I try to use SystemInit() (system.c)to initialize my system clock. some definitions was chip_setup.h. My question is how to config these. For example, I want to use 12M external crystal as clock source, and get 30Mhz.
标签 (2)
标记 (2)
1,681 次查看
jeremyzhou
Hi Roger Wang,
I'd highly recommend you to use the MCUXpresso Config Tools to configure the clock, the tool provides a GUI allows developers to quickly build a custom clock and generate initialization C code for a custom board, so please give a try.
TIC
1,682 次查看
jeremyzhou
Hi Roger Wang,
TIC
