LPC845 Power-Down
LPC845 Power-Down
14,871 次查看
DirkP
Hi All,
I'm busy on a custom made board to develop a remote control using the LPC-845.
However, I'm unable to get the system in a mode that consumes the power as stated in the device sheets.
In power down mode it will not go below 500 uA.
So I took the LPC845-BRK board to test (no peripheral devices attached and easy to measure at the JP1 jumper)
Still no luck, tried everything (see attached source code) to see if I forgot something.
Also 500 uA at power-down, 320 uA at deep power-down.
So did I forget something ?
Dirk.
14,482 次查看
ZhangJennie
HI @DirkP
I found a BRK board and tested it. I can reproduce the problem. The current comsuption is on PIO0_07 pin and Vdda to Vssa through RV1. This additional comsuption could be at least 0.3mA.  To verify it, removing RV1 on this pin can reduce the current from 0.36mA to 42.5 uA on my side
Hope this will help you.
Jun Zhang
10 回复数
14,856 次查看
ZhangJennie
Hello DirkP ,
I ever wrote article on this topic, which guides how to measure current correctly in power down mode with LPCXpresso845MAX board.
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/LPC-Why-My-Low-Power-Current-Is-Differen...
Hope this will help you,
Jun Zhang
14,851 次查看
DirkP
Hello Jun,
Thanks for your response.
I did read your article and it explains why 1.5 uA is difficult to get.
But 60 uA should easily be possible and 500 uA is a long way from it
Dirk.
14,771 次查看
ZhangJennie
Hi DirkP
It seems you are using custom board.
There are two points we need to check.
1. don't connect debugger. measure the current in standalone mode
2.  set the unused GPIO as a pull-up input.
If the problem persists, measure the individual gpio. which pin has higter current?
Have a nice day
Jun Zhang
14,765 次查看
DirkP
Hi Jun,
I put all pins to input with pull-up (see attached source code).
Also used a wallplug socket (to USB 5Volt)  to be sure no connection was made to the programming/terminal socket.
As I expected, current dropped a bit (on account of the terminal socket) but not much:
The board itself is a regular breakout board from NXP:
As I said, I don't have connections to the GPIO pins, so how to measure ?
Dirk.
14,712 次查看
ZhangJennie
Hi DirkP ,
I don't have a bRK board to test.
the statistics are based on the condition of Vdd=3.3 . and did you test if the result is the same for other low power mode?
Jun Zhang
标记 (1)
14,703 次查看
DirkP
Hi Jun,
Power comes from the usb but the measurepoints are on the chip itself so that shouldn't be a problem (see attachment).
Power is:
Regular  Operation: 7.04 mA
Sleep: 2.60 mA
Deep Sleep: 0.67 mA
Power Down: 0.46 mA
Deep Power Down: 0.32 mA
I must say, it will be difficult to investigate if you don't have the hardware itself.
It's just a standard breakout board tho.
Dirk.
14,653 次查看
ZhangJennie
Hi DirkP
I checked manual. there is one point, please check if you are aware: A narrow
PCB trace connects the two holes for JP1, so this must be cut with a knife before installing
the header in order for an ammeter to be able to measure the current.
Have a nice day,
Jun Zhang
14,640 次查看
DirkP
Hello Jun,
Of course I cut this trace, otherwise I would measure no current at all
Dirk.
14,483 次查看
ZhangJennie
HI @DirkP
Jun Zhang
14,469 次查看
DirkP
Hi Jun,
You're quite right, somehow I overlooked this voltage divider.
Thanks for the help.
Dirk.
%3CLINGO-SUB%20id%3D%22lingo-sub-1911984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC845%E6%96%AD%E7%94%B5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1911984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%BF%99%E4%BA%8E%E4%BD%BF%E7%94%A8%20LPC-845%20%E5%AE%9A%E5%88%B6%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%9D%A5%E5%BC%80%E5%8F%91%E9%81%A5%E6%8E%A7%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%A9%E7%B3%BB%E7%BB%9F%E8%BF%9B%E5%85%A5%E8%AE%BE%E5%A4%87%E8%AF%B4%E6%98%8E%E4%B9%A6%E4%B8%AD%E8%A7%84%E5%AE%9A%E7%9A%84%E6%B6%88%E8%80%97%E7%94%B5%E9%87%8F%E7%9A%84%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%96%AD%E7%94%B5%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E7%94%B5%E6%B5%81%E4%B8%8D%E4%BC%9A%E4%BD%8E%E4%BA%8E%20500%20uA%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E6%88%91%E6%8B%BF%20LPC845-BRK%20%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%88%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%20JP1%20%E8%B7%B3%E7%BA%BF%E4%B8%8A%E5%BE%88%E5%AE%B9%E6%98%93%E6%B5%8B%E9%87%8F%EF%BC%89%3C%2FP%3E%3CP%3E%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E8%BF%90%E6%B0%94%EF%BC%8C%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%80%E5%88%87%EF%BC%88%E5%8F%82%E8%A7%81%E9%99%84%E4%BB%B6%E7%9A%84%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%89%E6%9D%A5%E6%9F%A5%E7%9C%8B%E6%98%AF%E5%90%A6%E5%BF%98%E8%AE%B0%E4%BA%86%E4%BB%80%E4%B9%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%AD%E7%94%B5%E6%97%B6%E4%B8%BA%20500%20uA%EF%BC%8C%E6%B7%B1%E5%BA%A6%E6%96%AD%E7%94%B5%E6%97%B6%E4%B8%BA%20320%20uA%E3%80%82%3C%2FP%3E%3CP%3E%E9%82%A3%E4%B9%88%E6%88%91%E6%98%AF%E4%B8%8D%E6%98%AF%E5%BF%98%E8%AE%B0%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%9F%AD%E5%89%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
