LPC55S36 I3C Slave Issue Handling Custom CCC with No Data
3,833件の閲覧回数
bell_huang
Two LPC5536-EVK boards were connected for I3C communication, with one configured as the I3C Master and the other as the I3C Slave.
When the Master sends a custom CCC with a data length of 0, the Slave misses to receive the kI3C_SlaveCompletionEvent.
Notes:
  • In the sample code I provided, please refer to the I3C_BusMasterCustomCCC function, where cmd.dataSize = 0; indicates the data length.
  • The CCC waveform output from the Master has been verified and is correct.
  • If the CCC includes data with length greater than 0, the Slave is able to receive the kI3C_SlaveCompletionEvent as expected.
Case: data length = 1
// Private Write
transfers[7]. event: TransmitEvent
transfers[8]. event: AddressMatchEvent
transfers[9]. event: ReceiveEvent
transfers[10]. event: CompletionEvent. status: 0, count: 6
// Private Read
transfers[0]. event: TransmitEvent
transfers[1]. event: AddressMatchEvent
transfers[2]. event: ReceiveEvent
transfers[3]. event: TransmitEvent
transfers[4]. event: AddressMatchEvent
transfers[5]. event: CompletionEvent. status: 0, count: 5
// Custom CCC
transfers[1]. event: TransmitEvent
transfers[2]. event: ReceivedCCCEvent
transfers[3]. event: AddressMatchEvent
transfers[4]. event: ReceiveEvent
transfers[5]. event: CompletionEvent. status: 0, count: 1
// Private Write
transfers[3]. event: CompletionEvent. status: 0, count: 6
// Private Read
Case: data length = 0
// Private Write
// Private Read
// Private Write (mix with some events from previous Custom CCC)
transfers[2]. event: TransmitEvent
transfers[3]. event: ReceivedCCCEvent
transfers[5]. event: ReceiveEvent
transfers[6]. event: ReceiveEvent
transfers[7]. event: CompletionEvent. status: 0, count: 0
// Private Read
3,328件の閲覧回数
Harry_Zhang
Hi @bell_huang
Thanks for your information.
I have tested it.
I tested it based on the
Case 2: I3C_MasterTransferNonBlocking (from fsl_i3c API)
uint8_t cmdId = 0xF0;
memset(&masterXfer, 0, sizeof(masterXfer));
masterXfer.slaveAddress = 0x7E;
masterXfer.data         = &cmdId;
masterXfer.dataSize     = 1;
masterXfer.direction    = kI3C_Write;
masterXfer.busType      = kI3C_TypeI3CSdr;
masterXfer.flags        = (uint32_t)kI3C_TransferNoStopFlag;
g_masterCompletionFlag = false;
I3C_MasterTransferNonBlocking(EXAMPLE_MASTER, &masterHandle, &masterXfer);
while (!g_masterCompletionFlag)
    __NOP();
if (g_completionStatus != kStatus_Success)
    PRINTF("I3C_MasterTransferNonBlocking Write cmdId failed: %d\r\n", g_completionStatus);
uint8_t data[10];
memset(data, 0, sizeof(data));
data[0] = 0x01;
data[1] = 0x02;
data[2] = 0x03;
masterXfer.slaveAddress = slaveAddr;
masterXfer.data         = data;
masterXfer.dataSize     = 0;
masterXfer.flags        = (uint32_t)kI3C_TransferRepeatedStartFlag;
    __NOP();
    PRINTF("I3C_MasterTransferNonBlocking Write data failed: %d\r\n", g_completionStatus);
I can reproduce this issue.
So i try to add some debug code.
In fsl_i3c.c
When Master send the RepeatStart. it will enter while(1);
And i checked the logic analyze.
The waveform is correct.
So currently, when you want to write date through nonblocking. The SDK only support the DataSize >0.
May I ask if you have datasize=0 with write  based on the nonblocking Related requirements?
If yes, you need modify related code.
Harry
6 返答(返信)
3,753件の閲覧回数
Harry_Zhang
Hi @bell_huang
Can you share your project so that I can reproduce this issue more easily?
Harry
3,730件の閲覧回数
bell_huang
Hi @Harry_Zhang ,
Test steps:
(1) Reset slave board
(2) Reset master board
    At this step, it can be observed that after the Slave receives the CCC, the callback does not trigger the kI3C_SlaveCompletionEvent.
(3, Optional) Click SW3 on master board
    Master read register
Also check out the configuration of CCC data length in I3C_BusMasterCustomCCC function of master code:
cmd.dataSize = 1;
--- Master log ---
data: 0x0
Write Custom CCC
Click SW3 to start
data: 0x65 // ---> Indicate that the slave received CCC successfully, so that the master can read the correct value
--- Slave log ---
transfers[4]. event: TransmitEvent
transfers[5]. event: TransmitEvent
transfers[6]. event: TransmitEvent
transfers[10]. event: TransmitEvent
transfers[11]. event: AddressMatchEvent
transfers[12]. event: CompletionEvent. status: 0, count: 0
transfers[5]. event: CompletionEvent. status: 0, count: 1 // ---> Received kI3C_SlaveCompletionEvent after received CCC event
// After clicked on master SW3
transfers[5]. event: CompletionEvent. status: 0, count: 0
--- Master log ---
data: 0x0
Write Custom CCC
Click SW3 to start
data: 0x90 // ---> Wrong value
--- Slave log ---
// ---> Miss kI3C_SlaveCompletionEvent here after receiving CCC event.
transfers[4]. event: ReceivedCCCEvent
transfers[7]. event: ReceivedCCCEvent
transfers[9]. event: CompletionEvent. status: 7904
transfers[11]. event: CompletionEvent. status: 0, count: 5
3,423件の閲覧回数
Harry_Zhang
Hi @bell_huang
Would it be possible to make minimal modifications based on the i3c SDK example to verify the this functionality?
Additionally, could you provide the waveform data?
Harry
3,407件の閲覧回数
bell_huang
I tried simplifying my example to be even more minimal than the SDK example.
I found that the issue occurs on the Master side, rather than on the Slave side as originally assumed.
In summary, when implementing a Custom CCC with no data on the Master, using I3C_MasterTransferBlocking works correctly. However, when using I3C_MasterTransferNonBlocking, the waveform is incorrect.
The expected waveform sequence for a Custom CCC is: 0x7E -> 0xF0 (Custom CCC) -> 0x09 (Slave Address). Below, I only show the waveform for the Slave Address. The following three cases use the same Slave driver, but different Master driver APIs.
Test steps:
(1) Reset Slave
(2) Reset Master
(3) Click Master SW3
Case 1: I3C_MasterTransferBlocking (from fsl_i3c API)
-> The waveform is correct.
result                  = I3C_MasterTransferBlocking(EXAMPLE_MASTER, &masterXfer);
if (result != kStatus_Success)
    PRINTF("I3C_MasterTransferBlocking Write cmdId failed: %d\r\n", result);
uint8_t data[10];
data[0] = 0x01;
data[1] = 0x02;
data[2] = 0x03;
    PRINTF("I3C_MasterTransferBlocking Write data failed: %d\r\n", result);
-> The Slave Address sent is incorrect, resulting in a NACK.
    __NOP();
uint8_t data[10];
data[0] = 0x01;
data[1] = 0x02;
data[2] = 0x03;
    __NOP();
If you change dataSize from 0 to 1, the waveform of Slave Address will be correct.
Case 3: I3C_BusMasterSendCCC (from fsl_component_i3c_adapter API)
-> Internally uses I3C_MasterTransferNonBlocking, so the behavior is the same as Case 2.
i3c_ccc_cmd_t cmd = {0};
uint8_t data[10];
data[0] = 0x01;
data[1] = 0x02;
data[2] = 0x03;
cmd.isRead   = false;
cmd.cmdId    = 0xF0;
cmd.destAddr = slaveAddr;
cmd.data     = data;
cmd.dataSize = 0;
status_t result = I3C_BusMasterSendCCC(&masterDev, &cmd);
    PRINTF("I3C_BusMasterSendCCC failed: %d\r\n", result);
3,329件の閲覧回数
Harry_Zhang
Hi @bell_huang
I have tested it.
    __NOP();
uint8_t data[10];
data[0] = 0x01;
data[1] = 0x02;
data[2] = 0x03;
    __NOP();
In fsl_i3c.c
Harry
3,317件の閲覧回数
bell_huang
Hi @Harry_Zhang ,
I’m not sure how to modify the code related to the non-blocking function. Fortunately, it is confirmed that the blocking function works correctly, so for now, I will use I3C_MasterTransferBlocking to implement the Custom CCC.
Since I typically use the higher-level API (fsl_component_i3c_adapter), it would be ideal if the NXP SDK team could address this issue in a future update. Once it is fixed, I will switch back to using I3C_BusMasterSendCCC for Custom CCC implementation.
%3CLINGO-SUB%20id%3D%22lingo-sub-2131548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55S36%20I3C%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%E5%95%8F%E9%A1%8C%EF%BC%9A%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AA%E3%81%97%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CCC%E3%81%AE%E5%87%A6%E7%90%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131548%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Flpcxpresso-boards%2Flpcxpresso55s36-development-board%3ALPCXpresso55S36%3F_gl%3D1*ynjdvb*_ga*Njc1NDM1MzQ0LjE3NDkxNzY4NDE.*_ga_WM5LE0KMSH*czE3NTIxMzMxOTYkbzIxJGcxJHQxNzUyMTM0MDUwJGo1OSRsMCRoMTEyMzgwOTEwNQ..%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ELPC5536-EVK%3C%2FA%3E%202%E5%80%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20I3C%20%E9%80%9A%E4%BF%A1%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%80%811%20%E3%81%A4%E3%81%AF%20I3C%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E3%82%82%E3%81%86%201%20%E3%81%A4%E3%81%AF%20I3C%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8C%3CSTRONG%3E%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%200%20%E3%81%AE%3C%2FSTRONG%3E%3CSTRONG%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC%20%E3%82%92%3C%2FSTRONG%3E%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%20kI3C_SlaveCompletionEvent%20%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E3%83%A1%E3%83%A2%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%A7%81%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81I3C_BusMasterCustomCCC%20%E9%96%A2%E6%95%B0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%80%81cmd.dataSize%20%3D%200%3B%20%E3%81%AF%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8B%E3%82%89%E3%81%AE%20CCC%20%E6%B3%A2%E5%BD%A2%E5%87%BA%E5%8A%9B%E3%81%AF%E6%A4%9C%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%A7%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECCC%20%E3%81%AB%E9%95%B7%E3%81%95%E3%81%8C%200%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AF%E6%9C%9F%E5%BE%85%E3%81%A9%E3%81%8A%E3%82%8A%E3%81%AB%20kI3C_SlaveCompletionEvent%20%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3ECASE%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%20%3D%201%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B8%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B9%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B10%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%206%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%205%3C%2FP%3E%3CP%3E%2F%2F%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CCC%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceivedCCCEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%201%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%206%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%205%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECASE%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%20%3D%200%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B8%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B9%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B10%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%206%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%205%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%20(%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC%20%E3%81%8B%E3%82%89%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%81%A8%E6%B7%B7%E5%90%88)%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceivedCCCEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B6%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%97%E3%83%A9%E3%82%A4%E3%83%99%E3%83%BC%E3%83%88%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%205%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147166%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E9%9D%9E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E6%A9%9F%E8%83%BD%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%B9%B8%E3%81%84%E3%81%AB%E3%82%82%E3%80%81%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E6%A9%9F%E8%83%BD%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81SO%E3%80%81%3CSTRONG%3EI3C_MasterTransferBlocking%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CCC%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E3%82%88%E3%82%8A%E9%AB%98%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%20API%20(fsl_component_i3c_adapter)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81NXP%20SDKs%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%8C%E5%B0%86%E6%9D%A5%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E5%AF%BE%E5%87%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%A8%E7%90%86%E6%83%B3%E7%9A%84%E3%81%A7%E3%81%99%E3%80%82%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC%20%E5%AE%9F%E8%A3%85%E3%81%AB%3CSTRONG%3EI3C_BusMasterSendCCC%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228396%22%20target%3D%22_blank%22%3E%40bell_huang%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%0A%3CP%3ECASE%202%3A%20I3C_MasterTransferNonBlocking%20(fsl_i3c%20API%E3%81%8B%E3%82%89)%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Euint8_t%20cmdId%20%3D%200xF0%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%200x7E%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20%26amp%3BcmdId%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%201%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferNoStopFlag%3B%0Ag_masterCompletionFlag%20%3D%20false%3B%0AI3C_MasterTransferNonBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterHandle%2C%20%26amp%3BmasterXfer)%3B%0Awhile%20(!g_masterCompletionFlag)%0A%7B%0A%20%20%20%20__NOP()%3B%0A%7D%0Aif%20(g_completionStatus%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferNonBlocking%20Write%20cmdId%20failed%3A%20%25d%5Cr%5Cn%22%2C%20g_completionStatus)%3B%0A%0A%0Auint8_t%20data%5B10%5D%3B%0Amemset(data%2C%200%2C%20sizeof(data))%3B%0Adata%5B0%5D%20%3D%200x01%3B%0Adata%5B1%5D%20%3D%200x02%3B%0Adata%5B2%5D%20%3D%200x03%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%20slaveAddr%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20data%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%200%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferRepeatedStartFlag%3B%0Ag_masterCompletionFlag%20%3D%20false%3B%0AI3C_MasterTransferNonBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterHandle%2C%20%26amp%3BmasterXfer)%3B%0Awhile%20(!g_masterCompletionFlag)%0A%7B%0A%20%20%20%20__NOP()%3B%0A%7D%0Aif%20(g_completionStatus%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferNonBlocking%20Write%20data%20failed%3A%20%25d%5Cr%5Cn%22%2C%20g_completionStatus)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BECAN%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Efsl_i3c.c%E5%86%85%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1754386837044.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1754386837044.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350960i16800DE69713CCE5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1754386837044.png%22%20alt%3D%22Harry_Zhang_0-1754386837044.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_0-1754386837044.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8CRepeatStart%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%80%82while(1)%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E5%88%86%E6%9E%90%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1754387004620.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1754387004620.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350961i32FD2C39C8A71638%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1754387004620.png%22%20alt%3D%22Harry_Zhang_1-1754387004620.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EHarry_Zhang_1-1754387004620.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%B3%A2%E5%BD%A2%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ESO%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%80%81%E9%9D%9E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E6%97%A5%E4%BB%98%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82SDK%20%E3%81%AF%20DataSize%20%26gt%3B0%20%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E9%96%A2%E9%80%A3%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E3%81%AB%20datasize%3D0%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E3%81%8A%E5%B0%8B%E3%81%AD%E3%81%97%E3%81%A6%E3%82%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3CSPAN%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144032%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81SDKs%20%E3%81%AE%E4%BE%8B%E3%82%88%E3%82%8A%E3%82%82%E3%81%95%E3%82%89%E3%81%AB%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E4%BE%8B%E3%82%92%E7%B0%A1%E7%B4%A0%E5%8C%96%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E5%BD%93%E5%88%9D%E6%83%B3%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%9F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E5%81%B4%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E5%81%B4%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E8%A6%81%E7%B4%84%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%AA%E3%81%84%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC%20%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%20%3CSTRONG%3EI3C_MasterTransferBlocking%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%20%3CSTRONG%3EI3C_MasterTransferNonBlocking%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%B3%A2%E5%BD%A2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC%20%E3%81%AE%E4%BA%88%E6%83%B3%E3%81%95%E3%82%8C%E3%82%8B%E6%B3%A2%E5%BD%A2%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%200x7E%20-%26gt%3B%200xF0%20(%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20CCC)%20-%26gt%3B%200x09%20(%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9)%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%AE%E3%81%BF%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AE%203%20%E3%81%A4%E3%81%AECASE%E3%81%A7%E3%81%AF%E3%80%81%E5%90%8C%E3%81%98%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20API%20%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FP%3E%3CP%3E%EF%BC%881%EF%BC%89%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%EF%BC%882%EF%BC%89%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%EF%BC%883%EF%BC%89%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCSW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3ECASE%201%3A%20I3C_MasterTransferBlocking%3C%2FSTRONG%3E%20(fsl_i3c%20API%E3%81%8B%E3%82%89)%3CBR%20%2F%3E%20-%26gt%3B%20%E6%B3%A2%E5%BD%A2%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Euint8_t%20cmdId%20%3D%200xF0%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%200x7E%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20%26amp%3BcmdId%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%201%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferNoStopFlag%3B%0Aresult%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20I3C_MasterTransferBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterXfer)%3B%0Aif%20(result%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferBlocking%20Write%20cmdId%20failed%3A%20%25d%5Cr%5Cn%22%2C%20result)%3B%0A%0Auint8_t%20data%5B10%5D%3B%0Amemset(data%2C%200%2C%20sizeof(data))%3B%0Adata%5B0%5D%20%3D%200x01%3B%0Adata%5B1%5D%20%3D%200x02%3B%0Adata%5B2%5D%20%3D%200x03%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%20slaveAddr%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20data%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%200%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferRepeatedStartFlag%3B%0Aresult%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3D%20I3C_MasterTransferBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterXfer)%3B%0Aif%20(result%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferBlocking%20Write%20data%20failed%3A%20%25d%5Cr%5Cn%22%2C%20result)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bell_huang_0-1753928201436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bell_huang_0-1753928201436.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350349iC97C90E23DA46556%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bell_huang_0-1753928201436.png%22%20alt%3D%22bell_huang_0-1753928201436.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebell_huang_0-1753928201436.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3ECASE%202%3A%20I3C_MasterTransferNonBlocking%3C%2FSTRONG%3E%20(fsl_i3c%20API%E3%81%8B%E3%82%89)%3CBR%20%2F%3E%20-%26gt%3B%20%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81NACK%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Euint8_t%20cmdId%20%3D%200xF0%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%200x7E%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20%26amp%3BcmdId%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%201%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferNoStopFlag%3B%0Ag_masterCompletionFlag%20%3D%20false%3B%0AI3C_MasterTransferNonBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterHandle%2C%20%26amp%3BmasterXfer)%3B%0Awhile%20(!g_masterCompletionFlag)%0A%7B%0A%20%20%20%20__NOP()%3B%0A%7D%0Aif%20(g_completionStatus%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferNonBlocking%20Write%20cmdId%20failed%3A%20%25d%5Cr%5Cn%22%2C%20g_completionStatus)%3B%0A%0A%0Auint8_t%20data%5B10%5D%3B%0Amemset(data%2C%200%2C%20sizeof(data))%3B%0Adata%5B0%5D%20%3D%200x01%3B%0Adata%5B1%5D%20%3D%200x02%3B%0Adata%5B2%5D%20%3D%200x03%3B%0A%0Amemset(%26amp%3BmasterXfer%2C%200%2C%20sizeof(masterXfer))%3B%0AmasterXfer.slaveAddress%20%3D%20slaveAddr%3B%0AmasterXfer.data%20%20%20%20%20%20%20%20%20%3D%20data%3B%0AmasterXfer.dataSize%20%20%20%20%20%3D%200%3B%0AmasterXfer.direction%20%20%20%20%3D%20kI3C_Write%3B%0AmasterXfer.busType%20%20%20%20%20%20%3D%20kI3C_TypeI3CSdr%3B%0AmasterXfer.flags%20%20%20%20%20%20%20%20%3D%20(uint32_t)kI3C_TransferRepeatedStartFlag%3B%0Ag_masterCompletionFlag%20%3D%20false%3B%0AI3C_MasterTransferNonBlocking(EXAMPLE_MASTER%2C%20%26amp%3BmasterHandle%2C%20%26amp%3BmasterXfer)%3B%0Awhile%20(!g_masterCompletionFlag)%0A%7B%0A%20%20%20%20__NOP()%3B%0A%7D%0Aif%20(g_completionStatus%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_MasterTransferNonBlocking%20Write%20data%20failed%3A%20%25d%5Cr%5Cn%22%2C%20g_completionStatus)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bell_huang_1-1753928285555.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bell_huang_1-1753928285555.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350350i355526341BE8F7BE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bell_huang_1-1753928285555.png%22%20alt%3D%22bell_huang_1-1753928285555.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebell_huang_1-1753928285555.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EdataSize%20%E3%82%92%200%20%E3%81%8B%E3%82%89%201%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81Slave%20Address%20%E3%81%AE%E6%B3%A2%E5%BD%A2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22bell_huang_2-1753928603654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22bell_huang_2-1753928603654.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350352iBDEBC58112A606BC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22bell_huang_2-1753928603654.png%22%20alt%3D%22bell_huang_2-1753928603654.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ebell_huang_2-1753928603654.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3ECASE%203%3A%20I3C_BusMasterSendCCC%3C%2FSTRONG%3E%20(fsl_component_i3c_adapter%20API%E3%81%8B%E3%82%89)%3CBR%20%2F%3E%20-%26gt%3B%20%E5%86%85%E9%83%A8%E7%9A%84%E3%81%AB%E3%81%AF%20I3C_MasterTransferNonBlocking%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%AFCASE%202%20%E3%81%A8%E5%90%8C%E3%81%98%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Euint8_t%20cmdId%20%3D%200xF0%3B%0A%0Ai3c_ccc_cmd_t%20cmd%20%3D%20%7B0%7D%3B%0Auint8_t%20data%5B10%5D%3B%0Amemset(data%2C%200%2C%20sizeof(data))%3B%0Adata%5B0%5D%20%3D%200x01%3B%0Adata%5B1%5D%20%3D%200x02%3B%0Adata%5B2%5D%20%3D%200x03%3B%0A%0Acmd.isRead%20%20%20%3D%20false%3B%0Acmd.cmdId%20%20%20%20%3D%200xF0%3B%0Acmd.destAddr%20%3D%20slaveAddr%3B%0Acmd.data%20%20%20%20%20%3D%20data%3B%0Acmd.dataSize%20%3D%200%3B%0Astatus_t%20result%20%3D%20I3C_BusMasterSendCCC(%26amp%3BmasterDev%2C%20%26amp%3Bcmd)%3B%0Aif%20(result%20!%3D%20kStatus_Success)%0A%20%20%20%20PRINTF(%22I3C_BusMasterSendCCC%20failed%3A%20%25d%5Cr%5Cn%22%2C%20result)%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143289%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228396%22%20target%3D%22_blank%22%3E%40bell_huang%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E6%A4%9C%E8%A8%BC%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81i3c%20SDKs%20%E3%81%AE%E4%BE%8B%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81%E6%B3%A2%E5%BD%A2%E3%83%87%E3%83%BC%E3%82%BF%E3%82%82%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133692%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%B9%E3%83%88%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FP%3E%3CP%3E%EF%BC%881%EF%BC%89%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%EF%BC%882%EF%BC%89%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8C%20CCC%20%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%20kI3C_SlaveCompletionEvent%20%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8CCAN%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%883%E3%80%81%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%EF%BC%89%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%20I3C_BusMasterCustomCCC%20%E9%96%A2%E6%95%B0%E3%81%AE%20CCC%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Ecmd.dataSize%20%3D%201%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%3CSPAN%3ECASE%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%20%3D%201%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E---%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AD%E3%82%B0%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%3A%200x0%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CCC%E3%82%92%E6%9B%B8%E3%81%8F%3C%2FP%3E%3CP%3ESW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%3A%200x65%20%2F%2F%20---%26gt%3B%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%8CCCC%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E---%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%AD%E3%82%B0%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B6%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B8%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B9%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3Etransfers%5B10%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B11%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B12%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FP%3E%3CP%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceivedCCCEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%201%20%2F%2F%20---%26gt%3B%20%3CSPAN%3ECCC%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%ABkI3C_SlaveCompletionEvent%3C%2FSPAN%3E%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCSW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%9F%E5%BE%8C%3C%2FP%3E%3CP%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%3CSPAN%3ECASE%3A%20%E3%83%87%E3%83%BC%E3%82%BF%E9%95%B7%20%3D%200%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E---%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AD%E3%82%B0%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%3A%200x0%3C%2FP%3E%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0CCC%E3%82%92%E6%9B%B8%E3%81%8F%3C%2FP%3E%3CP%3ESW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%BC%E3%82%BF%3A%200x90%20%2F%2F%20---%26gt%3B%20%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%80%A4%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E---%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%AD%E3%82%B0%20---%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B6%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B8%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B9%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3Etransfers%5B10%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B11%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B12%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%200%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20---%26gt%3B%20%3CSPAN%3ECCC%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%20kI3C_SlaveCompletionEvent%20%E3%82%92%E3%83%9F%E3%82%B9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BCSW3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%9F%E5%BE%8C%3C%2FP%3E%3CP%3E%E7%A7%BB%E8%BB%A2%5B0%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B1%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B2%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B3%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B4%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceivedCCCEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B5%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceiveEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B6%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B7%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20ReceivedCCCEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B8%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20AddressMatchEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B9%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%207904%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B10%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20TransmitEvent%3CBR%20%2F%3E%E7%A7%BB%E8%BB%A2%5B11%5D%E3%80%82%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3A%20CompletionEvent%E3%80%82%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%200%E3%80%81%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%205%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55S36%20I3C%20Slave%20Issue%20Handling%20Custom%20CCC%20with%20No%20Data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228396%22%20target%3D%22_blank%22%3E%40bell_huang%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%88%E3%82%8A%E7%B0%A1%E5%8D%98%E3%81%AB%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
