LPC553x I3C PUR Signal availability
mf89
the LPC553x MCU Features a Hardware I3C Peripheral. Is the "PUR" Pull Up resistor control Pin only available in the 100 Pin Package ?
If yes is there an alternative solution for the 64 and 48 Pin Package to handle external Pull Ups on SDA line ?
Dezheng_Tang
Yes, only 100-pin package has PUR pin on external SDA pull-up, for smaller package, you have to configure a pin as GPIO and toggle it to control the external SDA pull-up. It's meant for a strong pull-up, not sure if it's always needed depending on your application.
Dezheng_Tang
%3CLINGO-SUB%20id%3D%22lingo-sub-2046551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC553x%20I3C%20PUR%20Signal%20availability%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ethe%20LPC553x%20MCU%20Features%20a%20Hardware%20I3C%20Peripheral.%20Is%20the%20%22PUR%22%20Pull%20Up%20resistor%20control%20Pin%20only%20available%20in%20the%20100%20Pin%20Package%20%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIf%20yes%20is%20there%20an%20alternative%20solution%20for%20the%2064%20and%2048%20Pin%20Package%20to%20handle%20external%20Pull%20Ups%20on%20SDA%20line%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2046551%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LPC553x%20I3C%20PUR%20Signal%20availability%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046604%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20only%20100-pin%20package%20has%20PUR%20pin%20on%20external%20SDA%20pull-up%2C%20for%20smaller%20package%2C%20you%20have%20to%20configure%20a%20pin%20as%20GPIO%20and%20toggle%20it%20to%20control%20the%20external%20SDA%20pull-up.%20It's%20meant%20for%20a%20strong%20pull-up%2C%20not%20sure%20if%20it's%20always%20needed%20depending%20on%20your%20application.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
