LPC5536 PMW register update issue
15,741 次查看
jimmyli
Contributor V
      We are developing a project by LPC3336, a question shown below.
      Hope you can help to check and fix.
     1>LPC5536 PMW0 SM0 configuration
      2>Question
           "Immediate"  can't take effect soon when set LDOK ( LDMOD is set to 1), we can't find the reason.
      Thanks very much.
10 回复数
15,587 次查看
I tested on my side, when set
pwmConfig.reloadLogic = kPWM_ReloadImmediate;
The reload value can take effect immediately.
I used the project you send to me, and just change gpio on my side. Full speed run can not analysis it,
use breakpoint and step debug.
1) Set a breakpoint at
2) After run at here, click step over:
3)Click Run, check signal:
Yellow: GPIO
Green: PWM.
Also you can change "pwmConfig.reloadLogic " to other configurations, observe result.
Alice
15,534 次查看
明省徐
Hi,Alice_Yang:
    I test again in EVK board,but result is not except. result show in picture, Also use the project.
15,573 次查看
明省徐
Hello,Alice_Yang
  I followed your steps, but the results were not as expected and were the same as the pictures I uploaded when I asked questions.
The mcu I tested is LPC5536, Can you share what your MCU is?
15,714 次查看
Hello @jimmyli
1) Please check register SM0CTRL, whether set LDMOD to 1.
2)Test with SDK demo "PWM", default  configuration is
/* Use full cycle reload */
pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle;
change it to " kPWM_ReloadImmediate", check whether  "Immediate"   take effect, also can compare the difference between two configurations.
Alice
15,690 次查看
明省徐
Hi, Alice_Yang:
    I Test with SDK demo "PWM", default  configuration,change reloadLogic to kPWM_ReloadImmediate.
/* Use kPWM_ReloadImmediate reload */
And check  LDMOD is 1.
But when i change pwm duty, the duty is not change Immediate.
My test code  is as follows:(pwm frequent is 10khz)
破坏者
Config change:
/* PWM A & PWM B form a complementary PWM pair */
pwmConfig.pairOperation = kPWM_ComplementaryPwmA;
pwmConfig.enableDebugMode = true;
infinite loop:
while (1U)
    /* Delay at least 100 PWM periods. */
    SDK_DelayAtLeastUs((1000000U / APP_DEFAULT_PWM_FREQUENCE) * 100, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY);
    Test_IO_Val_Set(1);
    if(test_AC_duty == 100){
      test_AC_duty = 0;
      PWM_UpdatePwmDutycycle(BOARD_PWM_BASEADDR, kPWM_Module_0, kPWM_PwmA, kPWM_SignedCenterAligned, test_AC_duty);
      PWM_SetPwmLdok(BOARD_PWM_BASEADDR, kPWM_Control_Module_0, true);
    else{
      test_AC_duty = 100;
    Test_IO_Val_Set(0);
15,635 次查看
Hello @明省徐
Could you please send the whole project, thanks.
Alice
15,616 次查看
明省徐
Hi, Alice_Yang:
    this is the project.
15,644 次查看
jimmyli
Contributor V
Hi Alice,
     Per replyed by xu mingsheng,  I can't find another way to fix this problem.
     Can you help to check again ?
     This problem will impact the PWM out from LPC5536, and lead to the project be pending.
     Thanks very much.
15,631 次查看
Hello @jimmyli
What about the result picture on your side? Is the same with 明省徐 ?
Alice
15,705 次查看
jimmyli
Contributor V
Hi Alice,
      Thanks very much.
      I will try again.
