LPC55 sprintf float values
3,404 次查看
SvenAsbach
Hi community,
I am trying to setup sprintf to print float numbers to string.
I tried everything I found, changed libraries, but nothing brought a success.
Either I get not the right result or I get an hardfault when trying to print negative float values.
Actual processor LPC5506
Floating point unit FPv5-SP-D16 Hard ABI set
current library setting Redlib semihost
I am using UART0 to print
PreProcessor settings
CPU_LPC5506JBD64
CPU_LPC5506JBD64_cm33
SDK_OS_BAREMETAL
SDK_DEBUGCONSOLE=2
SERIAL_PORT_TYPE_UART=1
PRINTF_FLOAT_ENABLE=1
SCANF_FLOAT_ENABLE=1
PRINTF_ADVANCED_ENABLE=1
SCANF_ADVANCED_ENABLE=1
__MCUXPRESSO
__USE_CMSIS
DEBUG
DISABLEFLOAT16
__REDLIB__
trying this code
float P_Value = 3.123456f;
float I_Value = 123.4567f;
float D_Value = 0.654321f;
sprintf(g_txBuffer, "rpm = %d, P_Value = %f, I_Value = %f, D_Value = %f \r", rpm_ist, P_Value, I_Value, D_Value);
no warnings or errors
And the result is
rpm = 206, P_Value = -0.000000, I_Value = -0.000000, D_Value = -0.000000 <CR>
Is there a way to get sprintf to print the right values including negative values or do I have to write my own converter?
What I do not see?
Thanks in advance
标签 (2)
标记 (3)
6 回复数
3,185 次查看
SvenAsbach
Stdio.h is included and used.
Where can I check in an existing project that the right printf version is used or where do I change it?
My preprocessor settings I have already send to you.
CR_INTEGER_PRINTF is not used in the build
Build is done with
arm-none-eabi-gcc -DCPU_LPC5506JBD64 -DCPU_LPC5506JBD64_cm33 -DSDK_OS_BAREMETAL -DSDK_DEBUGCONSOLE=2 -DSERIAL_PORT_TYPE_UART=1 -DPRINTF_FLOAT_ENABLE=1 -DSCANF_FLOAT_ENABLE=1 -DPRINTF_ADVANCED_ENABLE=1 -DSCANF_ADVANCED_ENABLE=1 -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -DDISABLEFLOAT16 -D__REDLIB__ xxxxx -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../CMSIS/DSP/Source/BayesFunctions/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP
3,090 次查看
ZhangJennie
Hi @SvenAsbach
Please make sure the project defined symbols and floating point set as below:
Hope this helps,
Jun Zhang
3,378 次查看
SvenAsbach
Thanks for the fast answer, but this does not help.
All what you are proposing is already set and tried, but no success.
Compiler uses this
arm-none-eabi-gcc -DCPU_LPC5506JBD64 -DCPU_LPC5506JBD64_cm33 -DSDK_OS_BAREMETAL -DSDK_DEBUGCONSOLE=2 -DSERIAL_PORT_TYPE_UART=1 -DPRINTF_FLOAT_ENABLE=1 -DSCANF_FLOAT_ENABLE=1 -DPRINTF_ADVANCED_ENABLE=1 -DSCANF_ADVANCED_ENABLE=1 -D__MCUXPRESSO -D__USE_CMSIS -DDEBUG -DDISABLEFLOAT16 -D__REDLIB__ -I"D:\Software\FC5706P_workspace\FC5706P101B001\drivers" -I"D:\Software\FC5706P_workspace\FC5706P101B001\device" -I"D:\Software\FC5706P_workspace\FC5706P101B001\component\serial_manager" -I"D:\Software\FC5706P_workspace\FC5706P101B001\utilities" -I"D:\Software\FC5706P_workspace\FC5706P101B001\component\uart" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS" -I"D:\Software\FC5706P_workspace\FC5706P101B001\component\lists" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS_driver\Include" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS\DSP\Include" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS\DSP\PrivateInclude" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS\DSP\Source\DistanceFunctions" -I"D:\Software\FC5706P_workspace\FC5706P101B001\CMSIS\NN\Include" -I"D:\Software\FC5706P_workspace\FC5706P101B001\board" -I"D:\Software\FC5706P_workspace\FC5706P101B001\source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../CMSIS/DSP/Source/BasicMathFunctions/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"CMSIS/DSP/Source/BasicMathFunctions/BasicMathFunctionsF16.d" -MT"CMSIS/DSP/Source/BasicMathFunctions/BasicMathFunctionsF16.o" -MT"CMSIS/DSP/Source/BasicMathFunctions/BasicMathFunctionsF16.d" -o "CMSIS/DSP/Source/BasicMathFunctions/BasicMathFunctionsF16.o" "../CMSIS/DSP/Source/BasicMathFunctions/BasicMathFunctionsF16.c"
3,259 次查看
ZhangJennie
Hi @SvenAsbach
Did you include "stdio.h"? We need to make sure we have this header file included.
I just tested sprintf with your code, there is no issue on my side. See attached video.
Please also make sure you use floating point version of printf.
Can you please checking your issue with refering my screenshot and testing video?
Best Regards
Jun Zhang
3,381 次查看
ZhangJennie
Hi @SvenAsbach
If you use SDK demo, please try to enable floating support
Make sure the defined symbols, printf float is enabled.
Does this work for you?
Best Regards
Jun Zhang
3,381 次查看
ErichStyger
Specialist I
Usually the problem is that CR_INTEGER_PRINTF  is still defined in the -D options list.
Make sure you do a full 'clean' of the build an retry.
These are my (working) defines and Linker settings:
__REDLIB__
CPU_LPC55S69JBD100
CPU_LPC55S69JBD100_cm33
CPU_LPC55S69JBD100_cm33_core0
SDK_DEBUGCONSOLE=1
__MCUXPRESSO
__USE_CMSIS
DEBUG
I hope this helps,
Erich
%3CLINGO-SUB%20id%3D%22lingo-sub-2158988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC55%20sprintf%20%E6%B5%AE%E7%82%B9%E6%95%B0%E5%80%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2158988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E8%AE%BE%E7%BD%AE%20sprintf%20%E5%B0%86%E6%B5%AE%E7%82%B9%E6%95%B0%E6%89%93%E5%8D%B0%E4%B8%BA%E5%AD%97%E7%AC%A6%E4%B8%B2%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E6%88%91%E6%89%BE%E5%88%B0%E7%9A%84%E6%89%80%E6%9C%89%E6%96%B9%E6%B3%95%EF%BC%8C%E6%9B%B4%E6%8D%A2%E4%BA%86%E5%9B%BE%E4%B9%A6%E9%A6%86%EF%BC%8C%E4%BD%86%E9%83%BD%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%89%93%E5%8D%B0%E8%B4%9F%E6%B5%AE%E7%82%B9%E6%95%B0%E5%80%BC%E6%97%B6%EF%BC%8C%E8%A6%81%E4%B9%88%E7%BB%93%E6%9E%9C%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%A6%81%E4%B9%88%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AE%9E%E9%99%85%E5%A4%84%E7%90%86%E5%99%A8%20LPC5506%20%3CBR%20%2F%3E%20%E6%B5%AE%E7%82%B9%E5%8D%95%E5%85%83%20fpv5-SP-D16%20Hard%20ABI%20%E8%AE%BE%E7%BD%AE%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%E5%BA%93%E8%AE%BE%E7%BD%AE%20Redlib%20semihost%20%3CBR%20%2F%3E%20%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20UART0%20%E6%89%93%E5%8D%B0%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%20CPU%20%3CBR%20%2F%3E%20_LPC5506JBD64%20CPU_lpc5506jbd64_cm33%20SDK_OS_BAREMETAL%20SDK_DEBUGCONSOLE%3D2%20SERIAL_PORT_TYPE_UART%3D1%20PRINTF_FLOAT_ENABLE%3D1%20SCANTF_FLOAT_ENABLE%3D1%20SCANTF_FLOAT_ENABLE%3D1%20SCANF_OS_BAREMETAL%20SDK_DEBUGCONSOLE%3D2%20F_FLOAT_ENABLE%3D1%20PRINTF_ADVANCED_ENABLE%3D1%20SCANF_ADVANCED_EN%20%3CBR%20%2F%3E%20ABLE%3D1%20__MCUXPRESSO%3CBR%20%2F%3E__%20USE_CMSIS%20%E8%B0%83%E8%AF%95%20DISABLEFLOAT16%20__REDLIB__%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%AF%95%E7%94%A8%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3EP_Value%20%3D%203.123456f%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3EI_Value%20%3D%20123.4567f%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%B5%AE%E7%82%B9%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3ED_Value%20%3D%200.654321f%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Esprintf(g_txBuffer%2C%22rpm%3D%25d%2C%20P_Value%20%3D%25f%2C%20I_Value%20%3D%25f%2C%20D_Value%20%3D%25f%20%5Cr%22%2Crpm_ist%2C%20P_Value%2C%20I_Value%2C%20D_Value)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B2%A1%E6%9C%89%E8%AD%A6%E5%91%8A%E6%88%96%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%80%8C%E7%BB%93%E6%9E%9C%E6%98%AF%3CBR%20%2F%3E%3C%2FSPAN%3Erpm%20%3D%20206%2C%20P_Value%20%3D%20-0.000000%E3%80%81I_Value%20%3D%20-0.000000%E3%80%81D_Value%20%3D%20-0.000000%3CCR%3E%3C%2FCR%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E8%AE%A9sprintf%E6%89%93%E5%8D%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E5%80%BC%EF%BC%8C%E5%8C%85%E6%8B%AC%E8%B4%9F%E5%80%BC%EF%BC%8C%E8%BF%98%E6%98%AF%E6%88%91%E5%BF%85%E9%A1%BB%E8%87%AA%E5%B7%B1%E7%BC%96%E5%86%99%E5%8F%98%E6%B5%81%E5%99%A8%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E7%9C%8B%E4%B8%8D%E5%88%B0%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A2%84%E5%85%88%E8%87%B4%E8%B0%A2%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2158988%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELPC55xx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F240955%22%20target%3D%22_blank%22%3E%40SvenAsbach%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E9%A1%B9%E7%9B%AE%E5%AE%9A%E4%B9%89%E7%9A%84%E7%AC%A6%E5%8F%B7%E5%92%8C%E6%B5%AE%E7%A9%BA%E7%82%B9%E8%AE%BE%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ZhangJennie_1-1757489388300.png%22%20style%3D%22width%3A%20842px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ZhangJennie_1-1757489388300.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F356192i35A6FF3571BCDFB1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ZhangJennie_1-1757489388300.png%22%20alt%3D%22ZhangJennie_1-1757489388300.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ZhangJennie_2-1757489476615.png%22%20style%3D%22width%3A%20847px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ZhangJennie_2-1757489476615.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F356193i3E77CF492C8D6624%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ZhangJennie_2-1757489476615.png%22%20alt%3D%22ZhangJennie_2-1757489476615.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%BC%A0%E4%BF%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8C%85%E5%90%AB%E5%B9%B6%E4%BD%BF%E7%94%A8%20Stdio.h%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%E7%8E%B0%E6%9C%89%E9%A1%B9%E7%9B%AE%E6%98%AF%E5%90%A6%E4%BD%BF%E7%94%A8%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20printf%20%E7%89%88%E6%9C%AC%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%E5%B7%B2%E7%BB%8F%E5%8F%91%E7%BB%99%E4%BD%A0%E4%BA%86%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%89%88%E6%9C%AC%E4%B8%AD%E6%9C%AA%E4%BD%BF%E7%94%A8%20CR_INTEGER_PRINTF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%E4%BD%BF%E7%94%A8%E5%AE%8C%E6%88%90%E7%89%88%E6%9C%AC%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSPAN%3Earm-none-eabi-gcc-DCPU_LPC5506JBD64-dcpu_lpc5506jbd64_cm33-DSDK_OS_BAREMETAL-DSDK_DEBUGCONSOLE%3D2-DSERIAL_PORT_TYPE_UART%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT__ADVANCED_ENABLE%3D1-DSCANF_ADVANCED_ENABLE%3D1-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-DDISABLEFLOAT16-D%20__REDLIB__%20xxxx-O0-fno-common-gdwarf-4-Wall-c-c-function-sections-fno-fdata-sections-fno-builtin-fmerge-constants-fmacro-prefix-map%3D%20%22...%2Fcmsis%2Fdsp%2Fsource%2FBayesFunctions%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-M%3C%2FSPAN%3E%20MD-MP%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2161277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161277%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F240955%22%20target%3D%22_blank%22%3E%40SvenAsbach%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%86%22stdio.h%22%20%E5%8C%85%E6%8B%AC%E5%9C%A8%E5%86%85%EF%BC%9F%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E7%A1%AE%E4%BF%9D%E5%8C%85%E5%90%AB%E8%BF%99%E4%B8%AA%E5%A4%B4%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E7%94%A8%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E6%B5%8B%E8%AF%95%E4%BA%86%20sprintf%EF%BC%8C%E6%88%91%E8%BF%99%E8%BE%B9%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%E5%8F%82%E8%A7%81%E6%89%80%E9%99%84%E8%A7%86%E9%A2%91%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E8%BF%98%E8%AF%B7%E7%A1%AE%E4%BF%9D%E4%BD%BF%E7%94%A8%E6%B5%AE%E7%A9%BA%E7%82%B9%E7%89%88%E6%9C%AC%E7%9A%84%20printf%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ZhangJennie_0-1756713922369.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ZhangJennie_0-1756713922369.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F354958i8204846956BF91D8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ZhangJennie_0-1756713922369.png%22%20alt%3D%22ZhangJennie_0-1756713922369.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%8F%82%E7%85%A7%E6%88%91%E7%9A%84%E6%88%AA%E5%9B%BE%E5%92%8C%E6%B5%8B%E8%AF%95%E8%A7%86%E9%A2%91%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%BC%A0%E4%BF%8A%20%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%BF%AB%E9%80%9F%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%BD%86%E8%BF%99%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E6%8F%90%E5%87%BA%E7%9A%84%E6%89%80%E6%9C%89%E5%BB%BA%E8%AE%AE%E9%83%BD%E5%B7%B2%E8%AE%BE%E5%AE%9A%E5%B9%B6%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%E7%BC%96%E8%AF%91%E5%99%A8%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%3CSPAN%3Earm-none-eabi-gcc-DCPU_LPC5506JBD64-dcpu_lpc5506jbd64_cm33-DSDK_OS_BAREMETAL-DSDK_DEBUGCONSOLE%3D2-DSERIAL_PORT_TYPE_UART%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT_ENABLE%3D1-DPRINTF_FLOAT__ADVANCED_ENABLE%3D1-DSCANF_ADVANCED_ENABLE%3D1-D%20__MCUXPRESSO%20-D__%20USE_CMSIS-DDEBUG-DDISABLEFLOAT16-D%20__REDLIB__-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Cdrivers%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Cdevice%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Ccomponent%5Cserial_manager%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Cutilities%20%22-I%20%22%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Ccomponent%5Cuart%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Ccomponent%5Clists%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS_driver%5CInclude%20%22-I%20%22%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS%5CDSP%5CInclude%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS%5CDSP%5CPrivateInclude%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS%5CDSP%5CSource%5CDistanceFunctions%20%22-I%20%22%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5CCMSIS%5CNN%5CInclude%20%22-I%20%22%20%22-I%20%22%5C%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%5Cboard%20D%3A%5CSoftware%5CFC5706P_workspace%5CFC5706P101B001%E6%9D%A5%E6%BA%90%20%22-O0-fno-common-g3-gdwarf-4-Wall-c-function-sections-function-sections-fdata-sections-fno-builtin-fmerge-constants-fmacro-prefix-map%3D%20%22...%2Fcmsis%2Fdsp%2Fsource%2FbasicMathFunctions%2F%20%22%20%3D-mcpu%3Dcortex-m33-mfpu%3Dfpv5-sp-d16-mfloat-abi%3Dhard-mthumb-D%20__REDLIB__-fstack-usage-specs%3Dredlib.specs-mmd-MP%20%22%20cmsis%2Fdsp%2FSource%2FbasicMathFunctions%2FbasicMathFunctions%2FbasicMathfunctions%2FbasicMathFunctionsF16.D%20%22-MT%22CMSIS%2FDSP%2FSource%2FBasicMathFunctions%2FBasicMathFunctionsF16.o%22-MT%22CMSIS%2FDSP%2FSource%2FBasicMathFunctions%2FBasicMathFunctionsF16.d%22-o%22CMSIS%2FDSP%2FSource%2FBasicMathFunctions%2FBasicMathFunctionsF16.o%22%22.%2FCMSIS%2FDSP%2FSource%2FBasicMathFunctions%2FBasicMathFunctionsF16.c%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159135%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F240955%22%20target%3D%22_blank%22%3E%40SvenAsbach%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BD%BF%E7%94%A8%20SDK%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%90%AF%E7%94%A8%E6%B5%AE%E7%A9%BA%E6%94%AF%E6%8C%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ZhangJennie_1-1756291243616.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ZhangJennie_1-1756291243616.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F354373iC8402FF15DF60B3C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ZhangJennie_1-1756291243616.png%22%20alt%3D%22ZhangJennie_1-1756291243616.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E7%A1%AE%E4%BF%9D%E5%B7%B2%E5%AE%9A%E4%B9%89%E7%9A%84%E7%AC%A6%E5%8F%B7%20printf%20float%20%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ZhangJennie_2-1756291670584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ZhangJennie_2-1756291670584.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F354375i2BAEA2BEDCC29A5A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ZhangJennie_2-1756291670584.png%22%20alt%3D%22ZhangJennie_2-1756291670584.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E5%AF%B9%E4%BD%A0%E6%9C%89%E7%94%A8%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%BC%A0%E4%BF%8A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2159131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC55%20sprintf%20float%20values%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2159131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%80%9A%E5%B8%B8%EF%BC%8C%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8E%20CR_INTEGER_PRINTF%20%E4%BB%8D%E5%AE%9A%E4%B9%89%E5%9C%A8%20-D%20%E9%80%89%E9%A1%B9%E5%88%97%E8%A1%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%8A%A1%E5%BF%85%E5%AE%8C%E5%85%A8%20%E2%80%9C%E6%B8%85%E7%90%86%E2%80%9D%20%E7%89%88%E6%9C%AC%EF%BC%8C%E7%84%B6%E5%90%8E%E9%87%8D%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E5%AE%9A%E4%B9%89%E5%92%8C%E9%93%BE%E6%8E%A5%E5%99%A8%E8%AE%BE%E7%BD%AE%EF%BC%88%E5%B7%A5%E4%BD%9C%E7%8A%B6%E6%80%81%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E__REDLIB__%3CBR%20%2F%3ECPU_LPC55S69JBD100%3CBR%20%2F%3ECPU_LPC55S69JBD100_cm33%3CBR%20%2F%3ECPU_LPC55S69JBD100_cm33_core0%3CBR%20%2F%3ESDK_DEBUGCONSOLE%3D1%3CBR%20%2F%3EPRINTF_FLOAT_ENABLE%3D1%3CBR%20%2F%3ESERIAL_PORT_TYPE_UART%3D1%3CBR%20%2F%3E__MCUXPRESSO%3CBR%20%2F%3E__%20USE_CMSIS%3CBR%20%2F%3EDEBUG%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ErichStyger_0-1756291258397.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ErichStyger_0-1756291258397.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F354374iB33B2EFD743797E1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ErichStyger_0-1756291258397.png%22%20alt%3D%22ErichStyger_0-1756291258397.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E
