LPC55 DMA and SPI memory maps
ソリューションへジャンプ
3,358件の閲覧回数
kbetts
I am writing an SPI DMA driver for the LPC55 as the NXP driver library doesn't quite do what I want. Is there a specification document available anywhere for the memory mapping of the SPI and DMA peripherals? I've pulled the structures out of the NXP drivers but I would like some more certainty that everything is as it should be, and to know whether the __I (input) __O (output) fields can be read from.
ラベル(2)
3,334件の閲覧回数
kbetts
I have now found this information in the user manual. I was looking in the separate DMA document before
4 返答(返信)
3,334件の閲覧回数
kbetts
3,066件の閲覧回数
ujwal_kumar_N_L
can you please post the documents you used ?any other updates regarding your driver?
3,043件の閲覧回数
kbetts
The User Manual can be found here:
https://www.nxp.com/webapp/Download?colCode=UM11126
The driver was developed for internal use by my company and is not available for distribution
3,341件の閲覧回数
Hello @kbetts
It seems this is the same question with your another ticket in salesforce, we have reply you on that thread.
Alice
