LPC546XX CTIMER configuration question
1,279件の閲覧回数
abdel12312
Hello NXP Community,
I'm working with an LPC546xx and need to know if a single CTIMER can simultaneously:
  1. Use channels 0 and 1 for input capture
  2. Use a match register (MR0) for interrupt generation on counter overflow without affecting any pins
My current setup:
  • CTIMER1 channels 0-1: Input capture
  • CTIMER1 channels 2-3: Timeout interrupts
I need to add timer overflow detection using a match register on the same timer. My though was to use Channels 0 or 1 MRs to be able to count number of overflows.
Since MCR (match control), CCR (capture control), and EMR (pin output) are separate registers, I believe they can be configured independently.
Can someone from NXP confirm if using match interrupts alongside input capture is supported?
1,160件の閲覧回数
Habib_MS
Hello @abdel12312, sorry for the late reply.
Yes, you can configure a channel in Input Capture/Match mode and utilize the match register simultaneously. However, the SDK does not provide an example demonstrating both functionalities together. As a reference, you can modify the example named lpcxpresso54628_ctimer_match_interrupt_example, which already includes the match functionality. This thread may also help guide your implementation.
Habib.
1,161件の閲覧回数
Habib_MS
Habib.
%3CLINGO-SUB%20id%3D%22lingo-sub-2172144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC546XX%20CTIMER%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20LPC546xx%20%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%811%20%E3%81%A4%E3%81%AE%20CTIMER%20%E3%81%8C%E5%90%8C%E6%99%82%E3%81%AB%E6%AC%A1%E3%81%AE%E3%81%93%E3%81%A8%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%AB%E3%81%AF%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB0%E3%81%A81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3E%E3%83%94%E3%83%B3%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%9A%E3%81%AB%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E6%99%82%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E7%94%9F%E6%88%90%E3%81%AB%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%EF%BC%88MR0%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%3C%2FP%3E%3CUL%3E%3CLI%3ECTIMER1%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%200-1%3A%20%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%3C%2FLI%3E%3CLI%3ECTIMER1%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%202-3%3A%20%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%90%8C%E3%81%98%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%AE%E3%83%9E%E3%83%83%E3%83%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E6%A4%9C%E5%87%BA%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E8%80%83%E3%81%88%E3%81%AF%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%200%20%E3%81%BE%E3%81%9F%E3%81%AF%201%20%E3%81%AE%20MR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E6%95%B0%E3%82%92%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EMCR%EF%BC%88%E3%83%9E%E3%83%83%E3%83%81%E5%88%B6%E5%BE%A1%EF%BC%89%E3%80%81CCR%EF%BC%88%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E5%88%B6%E5%BE%A1%EF%BC%89%E3%80%81EMR%EF%BC%88%E3%83%94%E3%83%B3%E5%87%BA%E5%8A%9B%EF%BC%89%E3%81%AF%E5%88%A5%E3%80%85%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%81%A8%E4%B8%80%E7%B7%92%E3%81%AB%E4%B8%80%E8%87%B4%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%20NXP%20%E3%81%AE%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AB%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC546XX%20CTIMER%20configuration%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254989%22%20target%3D%22_blank%22%3E%40abdel12312%3C%2FA%3E%20%E3%80%81%E8%BF%94%E4%BF%A1%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%AF%E3%81%84%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E5%85%A5%E5%8A%9B%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%2F%E3%83%9E%E3%83%83%E3%83%81%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81%E3%83%9E%E3%83%83%E3%83%81%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81SDKs%20%E3%81%A7%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E7%A4%BA%E3%81%99%E4%BE%8B%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%8F%82%E8%80%83%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%B8%80%E8%87%B4%E6%A9%9F%E8%83%BD%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20lpcxpresso54628_ctimer_match_interrupt_example%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E4%BE%8B%E3%82%92%E5%A4%89%E6%9B%B4CAN%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-SDK%2FCTimer-capture-examples-for-LPC54608%2Fm-p%2F819863%22%20target%3D%22_self%22%3EThread%E3%81%AF%3C%2FA%3E%E5%AE%9F%E8%A3%85%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E3%82%82%E5%BD%B9%E7%AB%8B%E3%81%A4%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3CBR%20%2F%3E%E3%83%8F%E3%83%93%E3%83%96%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
