LPC54608 pins pull up on reset
1,717 次查看
F_Vaquero
Most of the pins of the LPC54608 are with pull up on reset state. May I change this behaviour? I've seen that other microcontrollers have a non volatile memory (FAIM) to set up whether we want pull up, pull down or high-z at pins on reset.
1,704 次查看
Hello F_Vaquero,
No, pins will be the reset states as Data sheet -> Table 4  Pin description.
1,705 次查看
Hello F_Vaquero,
1,694 次查看
F_Vaquero
Thank you for your confirmation. Do you know why most of the pins are pull-up? This complicates a bit hardware design and for many years the "standard" reset state of pins has been high-Z.
1,712 次查看
frank_m
Senior Contributor III
I think not.
Check MCU user manual (UM10912.pdf), all peripheral register description sections describe a fixed reset value.
