LPC54608 pins pull up on reset
2,672件の閲覧回数
F_Vaquero
Most of the pins of the LPC54608 are with pull up on reset state. May I change this behaviour? I've seen that other microcontrollers have a non volatile memory (FAIM) to set up whether we want pull up, pull down or high-z at pins on reset.
2,659件の閲覧回数
Hello F_Vaquero,
No, pins will be the reset states as Data sheet -> Table 4  Pin description.
3 返答(返信)
2,660件の閲覧回数
Hello F_Vaquero,
2,649件の閲覧回数
F_Vaquero
Thank you for your confirmation. Do you know why most of the pins are pull-up? This complicates a bit hardware design and for many years the "standard" reset state of pins has been high-Z.
2,667件の閲覧回数
frank_m
Senior Contributor III
I think not.
Check MCU user manual (UM10912.pdf), all peripheral register description sections describe a fixed reset value.
