I am referencing to both the User Manual and the Datasheet of LPC5410x and noticed the following:
From (User Manual) UM10850:
For clock generation, it states that External clock input can be up to 24 MHz.
From Product datasheet:
It states that External clock input for clock frequencies of up to 25 MHz.
Can you please advise which statement is correct?
Kenneth
Solved! Go to Solution.
Hello @kennethkong852
Datasheet is correct.
I will escalate the UM issue to DOC team.
Thanks for your sharing.
Alice
Hi Alice,
Thank you for the reply and information there!
When I use the Clocks Config Tool (accessed from SDK Builder), I noticed that for the Configurator would not allow me to type in 25 MHz for CLKIN input. It's limited to 24 MHz.
Please see attached photo for reference.
CLKIN values
BR,
Kenneth
