LPC54102 Max Freq of External clock input
kennethkong852
I am referencing to both the User Manual and the Datasheet of LPC5410x and noticed the following:
From (User Manual) UM10850:
For clock generation, it states that External clock input can be up to 24 MHz.
From Product datasheet:
It states that External clock input for clock frequencies of up to 25 MHz.
Can you please advise which statement is correct?
Kenneth
Hello @kennethkong852
Thanks for your report.
This is a bug in the Clocks Config Tool. The issue arises because the new version of DS has changed the frequency from 24M to 25M. In old version DS, still 24MHZ.
I will report this bug to the Config Tool development team promptly.
For now, if you need to use 25MHZ, please configure it via code.
I apologize for the inconvenience this has caused you.
Alice
Datasheet is correct.
I will escalate the UM issue to DOC team.
Thanks for your sharing.
Alice
kennethkong852
Hi Alice,
Thank you for the reply and information there!
When I use the Clocks Config Tool (accessed from SDK Builder), I noticed that for the Configurator would not allow me to type in 25 MHz for CLKIN input.  It's limited to 24 MHz.
Please see attached photo for reference.
CLKIN valuesCLKIN values
BR,
Kenneth
Tags (2)
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2141190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC54102%20Max%20Freq%20of%20External%20clock%20input%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20referencing%20to%20both%20the%20User%20Manual%20and%20the%20Datasheet%20of%20LPC5410x%20and%20noticed%20the%20following%3A%3C%2FP%3E%3CP%3EFrom%20(User%20Manual)%20UM10850%3A%3CBR%20%2F%3EFor%20clock%20generation%2C%20it%20states%20that%20External%20clock%20input%20can%20be%20up%20to%2024%20MHz.%3C%2FP%3E%3CP%3EFrom%20Product%20datasheet%3A%3CBR%20%2F%3EIt%20states%20that%26nbsp%3BExternal%20clock%20input%20for%20clock%20frequencies%20of%20up%20to%2025%20MHz.%3C%2FP%3E%3CP%3ECan%20you%20please%20advise%20which%20statement%20is%20correct%3F%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EKenneth%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2141190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ELPC54xxx%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC54102%20Max%20Freq%20of%20External%20clock%20input%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199889%22%20target%3D%22_blank%22%3E%40kennethkong852%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20margin-top%3A%200px%20!important%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EThanks%20for%20your%20report.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EThis%20is%20a%20bug%20in%20the%20Clocks%20Config%20Tool.%20The%20issue%20arises%20because%20the%20new%20version%20of%20DS%20has%20changed%20the%20frequency%20from%2024M%20to%2025M.%20In%20old%20version%20DS%2C%20still%2024MHZ.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EI%20will%20report%20this%20bug%20to%20the%20Config%20Tool%20development%20team%20promptly.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EFor%20now%2C%20if%20you%20need%20to%20use%2025MHZ%2C%20please%20configure%20it%20via%20code.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EI%20apologize%20for%20the%20inconvenience%20this%20has%20caused%20you.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EBR%3C%2FDIV%3E%0A%3CDIV%20class%3D%22auto-hide-last-sibling-br%20paragraph-JOTKXA%20paragraph-element%20br-paragraph-space%22%20style%3D%22outline%3A%20none%3B%20-webkit-font-smoothing%3A%20antialiased%3B%20box-sizing%3A%20border-box%3B%20-webkit-tap-highlight-color%3A%20rgba(0%2C%200%2C%200%2C%200)%3B%20--tw-translate-y%3A%200%3B%20--tw-rotate%3A%200%3B%20--tw-skew-x%3A%200%3B%20--tw-skew-y%3A%200%3B%20--tw-scale-x%3A%201%3B%20--tw-scale-y%3A%201%3B%20line-height%3A%2028px%3B%20overflow-anchor%3A%20auto%3B%20font-size%3A%2016px%3B%20font-weight%3A%20400%3B%20color%3A%20rgba(0%2C%200%2C%200%2C%200.85)%20!important%3B%20font-family%3A%20Inter%2C%20-apple-system%2C%20BlinkMacSystemFont%2C%20'Segoe%20UI'%2C%20'SF%20Pro%20SC'%2C%20'SF%20Pro%20Display'%2C%20'SF%20Pro%20Icons'%2C%20'PingFang%20SC'%2C%20'Hiragino%20Sans%20GB'%2C%20'Microsoft%20YaHei'%2C%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20sans-serif%3B%20font-style%3A%20normal%3B%20font-variant-ligatures%3A%20normal%3B%20font-variant-caps%3A%20normal%3B%20letter-spacing%3A%20normal%3B%20orphans%3A%202%3B%20text-align%3A%20start%3B%20text-indent%3A%200px%3B%20text-transform%3A%20none%3B%20widows%3A%202%3B%20word-spacing%3A%200px%3B%20-webkit-text-stroke-width%3A%200px%3B%20white-space%3A%20normal%3B%20background-color%3A%20%23ffffff%3B%20text-decoration-thickness%3A%20initial%3B%20text-decoration-style%3A%20initial%3B%20text-decoration-color%3A%20initial%3B%22%3EAlice%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC54102%20Max%20Freq%20of%20External%20clock%20input%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Alice%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20the%20reply%20and%20information%20there!%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EWhen%20I%20use%20the%20Clocks%20Config%20Tool%20(accessed%20from%20SDK%20Builder)%2C%20I%20noticed%20that%20for%20the%20Configurator%20would%20not%20allow%20me%20to%20type%20in%2025%20MHz%20for%20CLKIN%20input.%26nbsp%3B%20It's%20limited%20to%2024%20MHz.%3C%2FP%3E%3CP%3EPlease%20see%20attached%20photo%20for%20reference.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CLKIN%20values%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CLKIN%20values%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350063iACC2ABE6C7981938%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22CLKIN_Max_Val.jpg%22%20alt%3D%22CLKIN%20values%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECLKIN%20values%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECLKIN%20values%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EBR%2C%3C%2FP%3E%3CP%3EKenneth%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2141379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPC54102%20Max%20Freq%20of%20External%20clock%20input%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141379%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199889%22%20target%3D%22_blank%22%3E%40kennethkong852%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDatasheet%20is%20correct.%3C%2FP%3E%0A%3CP%3EExternal%20clock%20input%20for%20clock%20frequencies%20of%20up%20to%2025%20MHz.%3C%2FP%3E%0A%3CP%3EI%20will%20escalate%20the%20UM%20issue%20to%20DOC%20team.%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20sharing.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E
