LPC54018,running both https get and mqtt client in the same device
2,551 次查看
nick_ng
I am running out of idea how to make my https get connection works while my mqtt client has already connected to a broker and running.
Are there any hints/tips on running https connection,i.e. getting a file over https while keeping a mqtt client connecting to another broker ?
For example, do I need to disconnect the mqtt connection during the procedure of connecting the https server?
标记 (1)
4 回复数
2,420 次查看
xiangjun_rong
Hi, Nick,
I have asked AE team, I will give you a reply after I get feedback.
XiangJun Rong
2,420 次查看
xiangjun_rong
Hi, Nick,
This is AE reply:
"You can use different sockets to connect mqtt server and https server that means you can keep mqtt connection while connecting https server.
Xiangjun Rong
2,420 次查看
nick_ng
Hi Xiangjun,
Thank you for your reply.
I did the same thing.. but I got two issues..
1. When I was trying to run ONLY the httpS to get a file, I always not able to get the last embedtls buffer size packet e.g the last 4096 bytes of that file
2. When I was trying use both the mqtt and https all together in the awsfreertos i.e. mqtt connected and subscribed to some topics and then triggered a download action (HTTPS get), during the phase of hand shaking, it jumps to hardfault.
Any ideas?
Thanks in advance,
Nick
2,420 次查看
xiangjun_rong
Hi, Nick,
You have to get the line which leads to hardware fault error although it is difficult.
XiangJun Rong
