LPC51U68 RTC backup
LPC51U68 RTC backup
1,959件の閲覧回数
br1
LPC51U68 has RTC but DON'T have battery backup pin (something like VBAT) ? How is it possible to backup the RTC?
1,938件の閲覧回数
FelipeGarcia
As you mentioned the LPC51U68 does not have a straightforward method to backup the RTC. The RTC module and the oscillator that drives it, run directly from device power pins. This means you will need to use some external circuitry such as a schottky diode.
Felipe
