How to install LPC11U68 SDK in MCUXpresso
已解决
跳至解决方案
4,065 次查看
phirung
I'm new to NXP. I've purchased an OM13058 dev board using LPC11U68.
I've downloaded and opened the MCUXpresso IDE v11.2.0.
When I go to the "Install MCUXpresso SDK's" window I get a list of boards or processors chosen by a tab at the top of the selection window.
Neither the OM13058 nor the LPC11U68 are listed when I examine the lists.
When I type either identifier into the filter, the lists disappear, from which I assume that neither are listed.
Could you please explain how to proceed? With thanks.
No one else has this question
标签 (1)
标记 (1)
1 解答
4,048 次查看
Hello Phirun Ng,
MCUXpresso SDK only support new part of LPC , not support LPC11u68.
You can use LPCopen to development this board, download from:
LPCOpen Software for LPC11XX | NXP
Hope it helps,
Alice
在原帖中查看解决方案
2 回复数
4,047 次查看
phirung
Yes, thanks, was at a loss how to proceed.
4,049 次查看
Hello Phirun Ng,
Hope it helps,
Alice
