LPC4353JBD208 question
3,204 次查看
uzunov16
Hello, I'm new in fixing electronics. I'm trying to fix my ploter PCB and i cheked with multimeter the capacitors. Every capacitor around the LPC4353JBD208 seems to be shorted. Does that means the MCU is shorted and i need to replace it?
Thank you!
3,164 次查看
xiangjun_rong
Okay, I suppose the MCU has broken down, you need a new one.
XiangJun Rong
6 回复数
3,178 次查看
uzunov16
I removed the MCU and now the capacitors are not shorted. That means i need new MCU?
3,105 次查看
uzunov16
Do i need a software to program the MCU after the replacement?
3,082 次查看
xiangjun_rong
The LPC4353 has on-chip flash, I suppose that you have to program your application code to the flash.
If you have the source code project, you can use keil, IAR or MCUXPresso tools to download the code.
If you has the *.bin or S_record file, you can use FlashMagic tools to download the code in ISP mode.
https://www.flashmagictool.com/download.html&d=flashmagic
Hope it can help you
XiangJun Rong
3,165 次查看
xiangjun_rong
XiangJun Rong
3,187 次查看
xiangjun_rong
I suppose that the VDD and GND pins are shorted either on board or inside silicon. Pls remove the LPC4353 from board and check if the shorting happens or not.
XiangJun Rong
3,185 次查看
uzunov16
Thank you! I'll try it.
%3CLINGO-SUB%20id%3D%22lingo-sub-1862187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPC4353JBD208%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%E7%94%B5%E5%AD%90%E7%BB%B4%E4%BF%AE%E6%96%B0%E6%89%8B%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BF%AE%E5%A4%8D%E6%88%91%E7%9A%84%E7%BB%98%E5%9B%BE%E4%BB%AA%20PCB%EF%BC%8C%E5%B9%B6%E7%94%A8%E4%B8%87%E7%94%A8%E8%A1%A8%E6%A3%80%E6%9F%A5%E4%BA%86%E7%94%B5%E5%AE%B9%E5%99%A8%E3%80%82LPC4353JBD208%20%E5%91%A8%E5%9B%B4%E7%9A%84%E6%AF%8F%E4%B8%AA%E7%94%B5%E5%AE%B9%E5%99%A8%E4%BC%BC%E4%B9%8E%E9%83%BD%E7%9F%AD%E8%B7%AF%E4%BA%86%E3%80%82%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20MCU%20%E7%9F%AD%E8%B7%AF%E4%BA%86%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%8D%A2%E5%AE%83%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1864584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC4353JBD208%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1864584%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9B%B4%E6%8D%A2%E5%90%8E%E6%88%91%E9%9C%80%E8%A6%81%E8%BD%AF%E4%BB%B6%E6%9D%A5%E5%AF%B9%20MCU%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC4353JBD208%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%A7%BB%E9%99%A4%E4%BA%86%20MCU%EF%BC%8C%E7%8E%B0%E5%9C%A8%E7%94%B5%E5%AE%B9%E5%99%A8%E6%B2%A1%E6%9C%89%E7%9F%AD%E8%B7%AF%E3%80%82%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%88%91%E9%9C%80%E8%A6%81%E6%96%B0%E7%9A%84%20MCU%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1862311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ALPC4353JBD208%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1862311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%E6%88%91%E4%BC%9A%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
