LPC4330 io pin impedance
1,620 次查看
timhutcheson
What is the correct PCB design impedance to use for an LPC4330 GPIO/SGPIO output pin?
Tnx,  Tim
1,518 次查看
kerryzhou
Hi Tim,
   This question seems the same as your another question post, and I already answer you in you another post:
Please check it.
If you still have question about it, please reply me directly in your another post, thank you!
Kerry
1,518 次查看
kerryzhou
Hi Tim,
Please check it.
Kerry
