LPC4078 Program Run in BootRom Area,could not jump to "main()"
863件の閲覧回数
tangjianbo_cumt
When under debug mode , use Keil v5,program is always run in "0x1FFF01S2  4201  TST    ri,r0"  ,and this is BootRom . My program could not jump to Main().
The CPU is continue resting ??
ラベル(2)
717件の閲覧回数
jeremyzhou
Before answering your question, I'd like to learn more information about this 'issue'. Whether you can clarify these below inquires.
1) Sharing the Option for Target in Keil.
2) Which board and demo you.
3) The voltage status of the ISP pin.
TIC
