LPC3250 and SDR SDRAM MT48H16M32LF
hyang1
I use the LPC3250 and have a SDR SDRAM MT48H16M32LF , how can i set all the registers? tks.
bernhardfink
Registers for SDRAM initialization need to be set by software.
Source code and drivers can be found here:  LPC32xx Common Driver Library (CDL)
There is also an app note covering this topic:  https://www.nxp.com/docs/en/application-note/AN10935.pdf
bernhardfink
hyang1
Thank you. I have done this, and it works now. Thanks.
