LPC2144
LPC2144
1,200 次查看
matiasTeko
Hi, i have a problem with the micro LPC2144FBD64. I've bought a lot of pieces of this micro from a broker, but i can't program them. I always used FLASHMAGIC with the same micro from another distributor with success,but now i have a Failed to Autobaud message. I cannot even upload my firware using ULINK, i have a JTAG communication problem message. Is there a kind of procedure for recover them?
Is there an alternative with the same pin out of LPC2144FBD64?
Thank you
1,185 次查看
PabloAvalos
Hi @matiasTeko
Thank you so much for using our community. I really appreciate your patience.
Regarding your question, some other alternatives with the same pinout might be the LPC2141FBD64, LPC2142FBD64, LPC2146FBD64 and LPC2148FBD64. You can refer to this link to see the datasheet and features of each one:
https://www.nxp.com/products/processors-and-microcontrollers/arm-microcontrollers/general-purpose-mc...
I will send you by email more information on your case that you created.
Please let me know if you have more questions. Otherwise, you may mark this answer as solution.
Thank you in advance.
Best Regards.
Pablo Avalos.
