- MCU: LPC 1830
- method : JTAG
- Error: can connect successfully , then erase and download error.
- Hardware: device running ok before. I just test it again, then I saw the problem.
已解决! 转到解答。
OK, the Segger support also suggest to use latest J-link software:
Could you please retry with the latest version of J-Link software package?
https://www.segger.com/downloads/jlink/#J-LinkSoftwareAndDocumentationPack
Hello andarm,
Recommend you first ask Jlink support:
https://www.segger.com/support/technical-support/
Also I can help you to contact if you need.
Alice
OK , Thanks very much.
I am not convenient to communicate with segger's FAE.
Could you convert it .
OK, i have submit a ticket to Segger support team, will tell you after I get any reply, thanks.
Thank you very much . I found it can work in JFlashV4.92. I think that segger's software compatiable issue.
