LPC1788 Pin description problem
2,209 次查看
Content originally posted in LPCWare by rodcab on Sun Oct 23 19:33:11 MST 2011
I want to change my project from LPC2478 to LPC1788, but when i take a look at the pin description to make the component i find a real problem...
i find 3 different files, the datasheet, UM10360 and UM10470, and for each i can find different description for each pin and/or dont see what mecanical pin have the P0[0] description for exemplo.
so what is the correct file that i need to read and use??
datasheet ??
UM10360 - usermanual for LPC17XX ??
UM10470 - usermanual for LPC178x/7x (this one dont show the fisical pin) ??
sorry for my poor english, any problem just ask.
2,107 次查看
Content originally posted in LPCWare by Marc Crandall on Wed Oct 26 12:22:15 MST 2011
And the UM is here:
http://ics.nxp.com/support/documents/microcontrollers/pdf/user.manual.lpc177x.lpc178x.pdf
All supporting docs and software can be found here:
http://ics.nxp.com/support/documents/microcontrollers/?scope=LPC1788
Note: the LPC2478 and LPC1788 are pin-for-pin compatible
2,107 次查看
Content originally posted in LPCWare by rodcab on Mon Oct 24 06:47:09 MST 2011
Tks for the reply atomicdog!!
i'll go by the datasheet then...
2,107 次查看
Content originally posted in LPCWare by atomicdog on Sun Oct 23 21:39:22 MST 2011
UM10360 is for different parts, not 1788...
The datasheet for 1788 shows the pins.
http://www.nxp.com/documents/data_sheet/LPC178X_7X.pdf
