LPC1788 Pin description problem
2,203件の閲覧回数
Content originally posted in LPCWare by rodcab on Sun Oct 23 19:33:11 MST 2011
I want to change my project from LPC2478 to LPC1788, but when i take a look at the pin description to make the component i find a real problem...
i find 3 different files, the datasheet, UM10360 and UM10470, and for each i can find different description for each pin and/or dont see what mecanical pin have the P0[0] description for exemplo.
so what is the correct file that i need to read and use??
datasheet ??
UM10360 - usermanual for LPC17XX ??
UM10470 - usermanual for LPC178x/7x (this one dont show the fisical pin) ??
sorry for my poor english, any problem just ask.
3 返答(返信)
2,101件の閲覧回数
Content originally posted in LPCWare by Marc Crandall on Wed Oct 26 12:22:15 MST 2011
And the UM is here:
http://ics.nxp.com/support/documents/microcontrollers/pdf/user.manual.lpc177x.lpc178x.pdf
All supporting docs and software can be found here:
http://ics.nxp.com/support/documents/microcontrollers/?scope=LPC1788
Note: the LPC2478 and LPC1788 are pin-for-pin compatible
2,101件の閲覧回数
Content originally posted in LPCWare by rodcab on Mon Oct 24 06:47:09 MST 2011
Tks for the reply atomicdog!!
i'll go by the datasheet then...
2,101件の閲覧回数
Content originally posted in LPCWare by atomicdog on Sun Oct 23 21:39:22 MST 2011
UM10360 is for different parts, not 1788...
The datasheet for 1788 shows the pins.
http://www.nxp.com/documents/data_sheet/LPC178X_7X.pdf
