LPC1769 QEI example in LPCOpen?
4,512 次查看
MAPC
Senior Contributor I
Does anybody have any example code for LPC1769 Quadrature Encoder Interface? I haven't found it in LPC1769 LPCOpen package.
Thanks!
Marco Coelho
DFAE - Siletec Eletronica
标签 (2)
3,854 次查看
jeremyzhou
Hi Marco Aurelio P. Coelho,
the opportunity to serve you.
Please checking the attachment.
TIC
6 回复数
3,855 次查看
jeremyzhou
TIC
3,854 次查看
MAPC
Thank you very much, Jeremy Zhou
Do you have a document explaining in more detail how this example works?
Your example runs in KEIL. What should we do to port this project to MCUXpresso?
Marco Coelho
3,854 次查看
jeremyzhou
Thanks for your reply.
The QEI demo not only can run in the KEIL but also can run in the IAR, however you should manually porting if you prefer the MCUXpresso.
The attached file has introduced the QEI demo in details and I think you can get the overview of the demo after reading it.
TIC
3,854 次查看
MAPC
Hi jeremyzhou
I just ported the example that you sent me to MCUXpresso. It is compiling perfectly. I don't know if it is running in a LPC1769, because I don't have a kit with this MCU here. But, it is supposed to be working.
Anyway, thank you very much for your help! Surely, it will be very helpful for the customer!
Marco Coelho
3,854 次查看
jeremyzhou
The QEI demo is available to LPC175x/6x series, definitely it includes the LPC1769.
TIC
3,854 次查看
MAPC
Hi jeremyzhou
The LPCOpen drivers from the example that you sent me are completely different from those which are in MCUXpresso LPCOPen.
Probably it won't be possible to reuse code and will be necessary to write a new project. If there was a demo code, it would be very helpful for us, but if there isn't, no problem...
Marco Coelho
