LPC1769 / OM13085 startup example
1,782 次查看
lmatte
Can I find anywhere a startup documentation example of this configuration?
I mean, I installed latest MCUXpresso, found a lot of data spread everywhere, but not a single guide to a silly application to test the system.
I created an application, but suddenly I see I have no Config Tools: the "MCUXpresso IDE user guide" mentions only how to work with an already present configuration. So I downloaded latest MCUXpresso Config Tools, but again I have no example or real guide on how to create this darned configuration - if I try to create it for a processor or stand alone board, it knows how to do it only for a subset of products (the latest?)
My horrible feeling is to be in an unruly mess of documentation, where no one has the guts to put some order, cause the parts are too many, with too many features and too many software options... Or... I'm simply wrong and ignorant: this is what I strongly hope! Please, confirm it! :smileyhappy:
1,655 次查看
jeremyzhou
Hi Luca Matteini,
for the opportunity to serve you.
NXP has provided the LPCOpen library for the developers to speed up and simplify development of LPC1769, then the developer can use the demos in the LPCOpen library as a startup template to develop their project.
Please give a try.
LPCOpen Software for LPC17XX | NXP
Note: MCUXpresso Config Tool hasn't supported the LPC1769 yet.
TIC
1,656 次查看
jeremyzhou
Hi Luca Matteini,
Please give a try.
TIC
