LP54608 ISP UART PROBLEM
1,613件の閲覧回数
Boopathy_Rangaraj
        I've a Custom Board with LPC54608. It was working fine. After changing the Osc Freq in Example Api's, the Controller suddenly went to Frozen state and there was no response in McuExpresso IDE. Then I tried to erase the flash banks in UART ISP mode using Flash Magic. It worked fine only once, again it went back to Frozen state. but now I couldn't able to program via ISP mode also.
what could be the issue..?? How can I enter ISP mode again..??
Thank you.
1,598件の閲覧回数
ZhangJennie
Hi Boopathy_Rangaraj
If you can't erase Flash in ISP mode. please make sure if your SWD interface was well designed. Refer this article:
https://community.nxp.com/t5/LPCXpresso-IDE-FAQs/Design-Considerations-for-Debug/m-p/469565
If no problem on SWD design. and we can't connect board in ISP, we need to consider if you enable ECRP by accident.
Please see this article I ever wrote:
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/LPC546xx-Understanding-ECRP/ta-p/1375263
The part is permanently disabled when
On-chip Image(s) are ruined
SWD access prohibited
ISP entries prohibited
Have a nice day,
Jun Zhang
