JTAG flash
JTAG flash
3,678 次查看
Content originally posted in LPCWare by Gritho on Fri Feb 07 02:06:40 MST 2014
Hi!
I need to flash/program and debug custom PCB with ARM Cortex M0 (LPC11C24) on board.
I have required JTAG pins, but I don't know how connect them to my
computer and flash/debug my programs.
Do you have some advices and which of your products could I use?
Thanks a lot!
6 回复数
3,630 次查看
Content originally posted in LPCWare by Gritho on Fri Feb 07 06:11:44 MST 2014
Quote: LabRat
And how do you debug?
That's a good question. I don't know yet, but I know that some solutions exist.
3,630 次查看
Content originally posted in LPCWare by LabRat on Fri Feb 07 05:37:13 MST 2014
Quote: Gritho
So to be indepedant...
3,630 次查看
Content originally posted in LPCWare by Gritho on Fri Feb 07 05:32:20 MST 2014
Thanks! but...
I used to use LPCXpresso, but I had several problems with. So to be indepedant and have the mastering of all the process, I program the LPC11C24 with my own crosscompilation, I used crosstool-ng to create it. Currently I use the UART to flash but I can't debug and that's not the easiest way to flash. It's for these reasons I would like use the SWD but without the constraint of LPCXpresso.
3,630 次查看
Content originally posted in LPCWare by LabRat on Fri Feb 07 04:03:56 MST 2014
Quote: Gritho
Do you have any idea how to use it with archlinux?
It's a good idea to use LPCXpresso & Link2.
http://www.lpcware.com/lpcxpresso/download
User Guide is talking about supported Linux versions:
• Linux – Ubuntu 11 onwards
• Linux – Fedora 17 onwards
Other distributions may run or not...
http://support.code-red-tech.com/CodeRedWiki/RunningOnLinux
3,630 次查看
Content originally posted in LPCWare by Gritho on Fri Feb 07 03:50:34 MST 2014
HO... ok!
Thank you for your answer and your links!! I will try LPC-Link2.
3,630 次查看
Content originally posted in LPCWare by LabRat on Fri Feb 07 03:00:06 MST 2014
LPC11C24 is not supporting JTAG  :O
The simplest way to debug/flash your 11C24 is a LPC-Link2.
http://www.embeddedartists.com/products/lpcxpresso/lpclink2.php
http://www.watterott.com/de/LPC-Link-2
It's working without problems with LPC11C24 and a simple SWD connection (and faster than a LPC-Link)....
