Issue with LP2364 UART communication
Content originally posted in LPCWare by NeethuG on Wed Oct 14 01:36:33 MST 2015
Dear All,
I am trying to implement UART0 communication in LPC2364.
I am using Sample Code Bundle for LPC23xx/LPC24xx Peripherals using Keil's μVision downloaded from the link
https://www.lpcware.com/content/nxpfile/sample-code-bundle-lpc23xxlpc24xx-peripherals-using-keils-%C...
In start up code OSCEN is set but when we check the "System control and status" window, the register is found reset.
I am not able to set a desired baud rate also.
There is problem with interrupt also... Interrupt is getting fired but its not entering into start up code.
Please give your valuable suggestions
