Issue in interfacing Barcode scanner using LPC4337 controller with LPCUSBLIB
RDGC_member
Hello ,
I’m currently working on barcode scanner interfacing with LPC4337 using lpcusblib (HID keyboard host example).
Issue: The USB1 host receives only the first character from the scanner after receiving few successful barcode readings, and then stalls. After rescanning, no further data transfers occur.
I’ve enabled USB1 interrupts and used HID_Host_ReceiveReport(), but suspect I’m missing proper IN packet handling or report clearing.
Has anyone implemented HID barcode scanning with lpcusblib on LPC microcontrollers? Any guidance or code snippets on handling continuous data transfer would be greatly helpful for me and appreciated.
i wanted to know that which are the conditions cause to clear the  pipe buffer. some times i receive full barcode properly. some times after first character nothing is received also the usb line gets stuck so that after that nothing is received for several times barcode scanning.
Thank you in advance!
#EmbeddedSystems #LPC4337 #USBHost #HID #Firmware
Hello @RDGC_member
My colleague has modified the LPC4337 USB host keyboard code to work with the NLS-HR11 barcode scanner on the LPCXpresso4337 EVK using MCUXpresso IDE. It works well.
Please see the screenshot of the changed code, as I cannot send the source code to you due to company policy. I have taken a screenshot for you to compare the differences. You can refer to it to check. Thank you.
Alice
RDGC_member
Hello All,
Thank you for sharing the screenshots and suggested code changes ,they were very helpful.
I have implemented the updates in our code and tested the setup across multiple test cases with our 1D barcode scanner. The barcode buffer no longer hangs, and the scanner is now working reliably with a receive time of 25 mili seconds.
I sincerely appreciate your efforts and prompt support in resolving this issue.
%3CLINGO-SUB%20id%3D%22lingo-sub-2427567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIssue%20in%20interfacing%20Barcode%20scanner%20using%20LPC4337%20controller%20with%20LPCUSBLIB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2427567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%2C%3C%2FP%3E%3CP%3EI%E2%80%99m%20currently%20working%20on%20barcode%20scanner%20interfacing%20with%20LPC4337%20using%20lpcusblib%20(HID%20keyboard%20host%20example).%26nbsp%3B%3C%2FP%3E%3CP%3EIssue%3A%20The%20USB1%20host%20receives%20only%20the%20first%20character%20from%20the%20scanner%20after%20receiving%20few%20successful%20barcode%20readings%2C%20and%20then%20stalls.%20After%20rescanning%2C%20no%20further%20data%20transfers%20occur.%3C%2FP%3E%3CP%3EI%E2%80%99ve%20enabled%20USB1%20interrupts%20and%20used%20HID_Host_ReceiveReport()%2C%20but%20suspect%20I%E2%80%99m%20missing%20proper%20IN%20packet%20handling%20or%20report%20clearing.%3C%2FP%3E%3CP%3EHas%20anyone%20implemented%20HID%20barcode%20scanning%20with%20lpcusblib%20on%20LPC%20microcontrollers%3F%20Any%20guidance%20or%20code%20snippets%20on%20handling%20continuous%20data%20transfer%20would%20be%20greatly%20helpful%20for%20me%20and%20appreciated.%3C%2FP%3E%3CP%3E%3CSPAN%3Ei%20wanted%20to%20know%20that%20which%20are%20the%20conditions%20cause%20to%20clear%20the%26nbsp%3B%20pipe%20buffer.%20some%20times%20i%20receive%20full%20barcode%20properly.%20some%20times%20after%20first%20character%20nothing%20is%20received%20also%20the%20usb%20line%20gets%20stuck%20so%20that%20after%20that%20nothing%20is%20received%20for%20several%20times%20barcode%20scanning.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThank%20you%20in%20advance!%3C%2FP%3E%3CP%3E%23EmbeddedSystems%20%23LPC4337%20%23USBHost%20%23HID%20%23Firmware%26nbsp%3B%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2427691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issue%20in%20interfacing%20Barcode%20scanner%20using%20LPC4337%20controller%20with%20LPCUSBLIB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2427691%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205299%22%20target%3D%22_blank%22%3E%40RDGC_member%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EMy%20colleague%20has%20modified%20the%20LPC4337%20USB%20host%20keyboard%20code%20to%20work%20with%20the%20NLS-HR11%20barcode%20scanner%20on%20the%20LPCXpresso4337%20EVK%20using%20MCUXpresso%20IDE.%20It%20works%20well.%3C%2FP%3E%0A%3CP%20class%3D%22p8i6j01%20paragraph%22%3EPlease%20see%20the%20screenshot%20of%20the%20changed%20code%2C%20as%20I%20cannot%20send%20the%20source%20code%20to%20you%20due%20to%20company%20policy.%20I%20have%20taken%20a%20screenshot%20for%20you%20to%20compare%20the%20differences.%20You%20can%20refer%20to%20it%20to%20check.%20Thank%20you.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1794537301916.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1794537301916.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1794537301916.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F399216i622CC47A18DE9AE8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1794537301916.png%22%20alt%3D%22Alice_Yang_0-1794537301916.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_1-1794537310094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_1-1794537310094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_1-1794537310094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F399217i7B87D6BB6B9837B7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_1-1794537310094.png%22%20alt%3D%22Alice_Yang_1-1794537310094.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_2-1794537315795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_2-1794537315795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_2-1794537315795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F399218iB6D544626D9E588D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_2-1794537315795.png%22%20alt%3D%22Alice_Yang_2-1794537315795.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2431105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Issue%20in%20interfacing%20Barcode%20scanner%20using%20LPC4337%20controller%20with%20LPCUSBLIB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2431105%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHello%20All%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%20for%20sharing%20the%20screenshots%20and%20suggested%20code%20changes%20%2Cthey%20were%20very%20helpful.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20have%20implemented%20the%20updates%20in%20our%20code%20and%20tested%20the%20setup%20across%20multiple%20test%20cases%20with%20our%201D%20barcode%20scanner.%3C%2FSPAN%3E%3CSPAN%3E%20The%20barcode%20buffer%20no%20longer%20hangs%2C%3C%2FSPAN%3E%3CSPAN%3E%20and%20the%20scanner%20is%20now%20working%20reliably%20with%20a%20receive%20time%20of%2025%20mili%20seconds.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20sincerely%20appreciate%20your%20efforts%20and%20prompt%20support%20in%20resolving%20this%20issue.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBest%20regards%2C%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
