Choosing an LPC Development Board for a First Sensor Project
wok-overheat
Fresh Out Contributor
Hello everyone,
Which LPC development board would you suggest for a beginner working on a small sensor project?
The learning goals would include reading sensor data, controlling an LED, and sending readings through UART. When comparing boards, how much importance should be given to debugger availability, example projects, accessible pins, and documentation?
Get Download Link
If you have worked with LPC boards, which features made getting started easier? Suggestions about useful introductory projects would also be appreciated.
Thank you for sharing your experience.
