ISP for LPC4357 using ethernet
3,429件の閲覧回数
Jaga123
Can I program LPC4357 through ISP mode using ethernet and FlashMagic tool? As this option is available in FlashMagic software. If yes, then is there any procedure available for that? I am not finding anything in LPC4357 user manual.
3 返答(返信)
3,386件の閲覧回数
Alex_Wang
Hi, @Jaga123
         You want to enter ISP mode through ethernet for Bootloader. Refer to 9.Ethernet for Bootloader in the attached manual.
         Hope this helps you.
Best regards, Alex
3,356件の閲覧回数
Jaga123
If I change this then should I able to do ISP programming through UART?
3,321件の閲覧回数
Alex_Wang
Hi, @Jaga123
        Of course, it is possible to enter the ISP mode through UART, select the corresponding COM port.
Best regards, Alex
