I2C
I2C
lpcware
Content originally posted in LPCWare by imroun1992 on Mon Sep 16 10:19:00 MST 2013
I put the datasheet now, can you help how to establish the I2C Communication between KEIL MCB 5347 and MPU 6050 accelerometer. I wan if it's possible a source code to initializing I2C Communication between these component and a code for initializing all axis of accelerometer.
http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Components/General%20IC/PS-MPU-6000A.pdf
Thanks You
lpcware
Content originally posted in LPCWare by imroun1992 on Wed Sep 18 14:30:36 MST 2013
Thanks You
This is not MCB 5347 but MCB 4357
