I2C in 1347
I2C in 1347
1,323 次查看
michaelscott993
Hello friends
im having trouble with I2C on my lpc1347, have no idea how to make it work...
is there any simple example for configuration i could use to learn?
for example i have function called setLED(255,0,0) and how can i send it to my device?
标记 (3)
1,152 次查看
Carlos_Mendoza
Hi Michael,
I would recommend you to use the periph_i2c example as base for your application, it is included in the LPCOpen package for the LPCXpreso LPC1347 board:
LPCOpen Software for LPC13XX|NXP
Here is a document that explains how to get started with LPCOpen:
https://community.nxp.com/docs/DOC-332667
Hope it helps!
Carlos Mendoza
Technical Support Engineer
