How to terminate running program?
2,313 次查看
avswathi2892
I am new to mc programming. can i give a user input while the program is running and my program should take that input and act accordingly?
2,251 次查看
soledad
For the record, which device are you using?
2,249 次查看
soledad
Yes, you can do it. Which IDE are you using?
Please check the document attached,  section 11 Debugging a Project.
Sol
