How to set up CTIMER capture channels in MCUXpresso Config Tools?
3,064 次查看
davenadler
Senior Contributor II
Just downloaded MCUXpresso Config Tools.
Using processor LPC5528.
When I set up a CTIMER, I see a tab to add match channels, but no way to add capture channels?
What am I missing?
Thanks!
Best Regards, Dave
标签 (3)
标记 (2)
4 回复数
2,976 次查看
xiangjun_rong
Hi, Dave,
You are right, I have tested the CTimer function of the peripheral configuration tools, the capture feature of Ctimer module is not supported by the version of peripheral configuration tools.
XiangJun Rong
2,976 次查看
davenadler
xiangjunrong‌ - Are you reporting this as a bug in Config Tool??
2,976 次查看
xiangjun_rong
Hi, Dave,
Thank you, I will report the issue to software team so that the capture feature can be supported.
XiangJun Rong
2,976 次查看
davenadler
Thanks xiangjun.rong‌, I understand this is confirmed as a bug in Config Tool.
Can you tell us when this will be fixed?
Thanks!
Best Regards, Dave
