How to run application using Lpcxpresso4367 (om13088) in non debug mode (standalone)
uaz
I'm currently trying something on the lpcxpresso4367 board.
I found that I'm unable to run my application without debugging. The target MCU LPC4367 just won't boot the internal flash which I believe has been flashed with my application (during debug).
Is there any particular setting that I need to do?
My current setting:
* JP1 - pin 1&2 shorted
* JP11 - pin 2&3 shorted
* JP3, JP5, JP2, JP4, - open
* JP6 - shorted
I believe UM10946-om13084 user guide has some errors:
- In 6.2 and 6.2: JP1 and JP2 are switched.
converse
Senior Contributor V
See the reply from LPCXpresso support in this thread:
https://community.nxp.com/thread/478633
uaz
Thanks! I totally missed that. It is now working fine without debugger
