How to do a software reset LPC54018
3,806件の閲覧回数
oscarniño
Somebody could tell me how to do a software reset on LCP54018?
ラベル(2)
3,518件の閲覧回数
ErichStyger
Specialist I
The ARM Cortex core has a register you can use to reset it, see How to Reset an ARM Cortex-M with Software | MCU on Eclipse
I hope this helps,
Erich
3,518件の閲覧回数
ErichStyger
Specialist I
I hope this helps,
Erich
3,518件の閲覧回数
oscarniño
Hi Erich
Thank you so much this was so helpful, I use MCUXpreso IDE and the function is __NVIC_SystemReset().
Beast Regards
