How can I enable the SPI interrupt from the MCUXpresso
Oxolotol
I have MCUXpresso itself,  docs for SDK, LPC804, MCUXpresso, and the example 'lpcxpresso804_board_lpc_lpc_i2c_interrupt_b2b_transfer_master_0'.  But can't find where in that project that the i2c is enabled, so I can port the functionality to my  project.  I have looked through in the MCUXpresso config perspectives,  I just can't find it.
Oxolotol
I found it in the peripherals view, you have to select the i2c checkbox to get the device configuration dialog box.
Miguel04
Hi @Oxolotol
I'm glad you find your way on your question, let me know if you need something else.
Best Regards, Miguel.
