General Topics help
General Topics help
Content originally posted in LPCWare by karanmehta93 on Mon Oct 15 07:05:50 MST 2012
1. What is the basic difference between RIT and timer in LPC1769 ?
If I want a code to generate a delay of n microseconds how can I do it?
2.How to use the index pin provided with QEI?
3. If i use one encoder with one capture and I want to record it's velocity how many timers will be needed??
4.Explain me THRE interrupt
Content originally posted in LPCWare by Daniel Widyanto on Mon Oct 15 20:39:14 MST 2012
Re-post from http://www.lpcware.com/showthread.php?t=3745
