Flexcomm serial single pin TXD usage
pejo
Hi there,
I don't have much experience in configuring Flexcomm and pin ports for LPC5504. I have the pin FC3_TXD_SCL_MISO_WS available but the rest of the FC3 serial port pins are being used as simple PIO/ Digital Input Output pins (Function=0).
I was wondering if it is possible to use only the Flexcomm 3 TXD pin for  communication (basically sending debug information) while keeping the rest of the pins for other functions like DIO.
Harry_Zhang
Hi @pejo
Yes, you can use only the FC3_TXD pin for communication while keeping the other Flexcomm 3 (FC3) pins as GPIO. The LPC5504 allows configuring individual pins for different functions within the Flexcomm peripheral, so you don’t need to enable the full UART interface.
Harry
Harry_Zhang
Hi @pejo
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2039807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexcomm%20serial%20single%20pin%20TXD%20usage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039807%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there%2C%3C%2FP%3E%3CP%3EI%20don't%20have%20much%20experience%20in%20configuring%20Flexcomm%20and%20pin%20ports%20for%20LPC5504.%20I%20have%20the%20pin%20FC3_TXD_SCL_MISO_WS%20available%20but%20the%20rest%20of%20the%20FC3%20serial%20port%20pins%20are%20being%20used%20as%20simple%20PIO%2F%20Digital%20Input%20Output%20pins%20(Function%3D0).%3C%2FP%3E%3CP%3EI%20was%20wondering%20if%20it%20is%20possible%20to%20use%20only%20the%20Flexcomm%203%20TXD%20pin%20for%26nbsp%3B%20communication%20(basically%20sending%20debug%20information)%20while%20keeping%20the%20rest%20of%20the%20pins%20for%20other%20functions%20like%20DIO.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Flexcomm%20serial%20single%20pin%20TXD%20usage%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232719%22%20target%3D%22_blank%22%3E%40pejo%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20you%20can%20use%20only%20the%20FC3_TXD%20pin%20for%20communication%20while%20keeping%20the%20other%20Flexcomm%203%20(FC3)%20pins%20as%20GPIO.%20The%20LPC5504%20allows%20configuring%20individual%20pins%20for%20different%20functions%20within%20the%20Flexcomm%20peripheral%2C%20so%20you%20don%E2%80%99t%20need%20to%20enable%20the%20full%20UART%20interface.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
