Expected current reduction not happen in sleep mode
1,517 次查看
Balaji_KG
      I am Balaji. I am working on LPC 1768 controller. When the controller is in sleep mode, I can't achieve the current reduction specified in the data sheet. I have attached some test results below for your reference. Kindly give me some solution.
ControllerLPC 1768
Voltage(RPS)3.3 v
Expected current reduction specified in datasheet2mA
Current reduced when the controller is in sleep modePeripherals Enabled
26mAGPIO,Timer0
25mAGPIO
23mATimer 0
22mAAll Peripherals disabled
1,486 次查看
Hello @Balaji_KG
Recommend you refer to the low power demo "periph_pmu" under LPCopen:
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/lpcopen-libr...
Alice
1,487 次查看
Hello @Balaji_KG
Alice
