flash
flash
Anshu
Am using lpc54s018 evk board, while trying to send and receive data using uart port, transmission is not happening. In debug port transmission and reception is happening and getting what ever data sending.
what can be the cause.
RaRo
Hello @Anshu,
Could you please give us more information about your issue?
Are you using an SDK's example? If so which one? How are you testing this?
Also, it could be useful to check the following community posts:
Best regards, Raul.
