Ethernet Code using PHY DP83848CLPC Expresso IDE software for coding LPC2478 controller
VijayaJangam1
I am working on ethernet drive code LPC2478 controller connect to PHY DP83848C IC used for Ethernet communication of two LPC2478 controller using Ethernet cable RSOUT CONNECT TO SST39VF3202C RST# ALSO CONNECT TO RSTOUT LPC2478 here in code I used SRAM for EMAC address data tx and Rx I want code in LPCXPresso IDE my SRAM Memory Address is 0x7FE00000 (ETH_RAM_BASE) A configurable location in RAM used to
store the actual data (descriptors, buffers). but in LPCXpresso IDE vender file LPC24xx.h file only MAC_RXDESCADDR (0xFFE00204) Fixed hardware address used to tell the how can solve this issue in LPCXPresso IDE
EMAC DMA where your memory
structures start.
Hello @VijayaJangam1
It seems this question is the same as the one posted at this link. My colleague will reply to you in that thread. No need create so many tickets.
Thank you.
