Ethernet Code using LPCXPRESSO IDE use internal SRAM
VijayaJangam1
using LPC2478 controller Ethernet Communication between two board  at one side set broadcast FF and data in string form  send from transmitter to receiver side give me Correct information I am attatched my file Ethernet code  at receiver side I am getting UUU data for 58 times give me corrections in my code and send a simple string from transmitter
Hello @VijayaJangam1
It seems this question is the same as the one posted at this link. My colleague will reply to you in that thread. No need create so many tickets.
Thank you.
