Duplicate variable declarations
393件の閲覧回数
Julian99
I am working on a new project using the LPC824 board and the downloaded lpcxpresso824max_new_project. It built, downloaded and debugged without problems. Initially I am trying to implement a 3-digit 7-segment LED display. I added declarations in peripherals.h and an update routine in main.c. When I build I get two errors - duplicated variable declarations. If I comment them out I get a message "undeclared variable". If I change the name of the variable I get the same duplication error. I have searched every source file in the project and cannot find any duplicates. One of the error messages is: -
/Applications/MCUXpressoIDE_25.6.136/ide/plugins/com.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204/tools/bin/../lib/gcc/arm-none-eabi/14.2.1/../../../../arm-none-eabi/bin/ld: ./source/peripherals.o:/Users/julian/Documents/MCUXpressoIDE_25.6.136/workspace/lpcxpresso824max_new_project/Debug/../source/peripherals.h:57: multiple definition of `CA_LUT'; ./source/main.o:/Users/julian/Documents/MCUXpressoIDE_25.6.136/workspace/lpcxpresso824max_new_project/Debug/../source/peripherals.h:57: first defined here
3 返答(返信)
327件の閲覧回数
Julian99
This is the entry in peripherals.h for both errors
// Lookup table for digits 0-9 (0 = ON, 1 = OFF)
const uint32_t CA_LUT[10] = {
//0: A, B, C, D, E, F are ON; G, DP are OFF
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_E)|(1<<SEG_F)),
// 1: B, C are ON
~((1<<SEG_B)|(1<<SEG_C)),
// 2: A, B, D, E, G are ON
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_D)|(1<<SEG_E)|(1<<SEG_G)),
// 3: A, B, C, D, G are ON
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_G)),
// 4: B, C, F, G are ON
~((1<<SEG_B)|(1<<SEG_C)|(1<<SEG_F)|(1<<SEG_G)),
// 5: A, C, D, F, G are ON
~((1<<SEG_A)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_F)|(1<<SEG_G)),
// 6: A, C, D, E, F, G are ON
~((1<<SEG_A)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_E)|(1<<SEG_F)|(1<<SEG_G)),
// 7: A, B, C are ON
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_C)),
// 8: All segments ON (A-G)
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_E)|(1<<SEG_F)|(1<<SEG_G)),
// 9: A, B, C, D, F, G are ON
~((1<<SEG_A)|(1<<SEG_B)|(1<<SEG_C)|(1<<SEG_D)|(1<<SEG_F)|(1<<SEG_G))
// Global variables holding the current numbers to be printed on Digits 1, 2, and 3
volatile uint8_t display_buffer[3] = {1, 2, 3}; // E.g., displays "123"
Both errors are used in main.c :-
uint8_t numeric_value = display_buffer[current_digit];
uint32_t segment_pattern = CA_LUT[numeric_value];
#include "peripherals.h" appears only in the following files: -
main.c, peripherals.c,
AS I mentioned I am coming over from CodeWarrior, so my knowledge of MCUX is probably dangerous (?????). I'm not sure whether a 7-segment display is a peripheral device (peripherals.h and c) or a declaration for a number of pins (pin_mux.h and c), but that can be sorted out later.
320件の閲覧回数
luis_maravilla
It could be that, as you define CA_LUT in peripherals.h both the main and peripherals.c call that file giving the duplicate error "multiple definition".
Could you help us try to add the declaration of CA_LUT only in peripherals.c instead of peripherals.h, and retry;
Do you have more declarations as this in peripherals.h? and they have the same error? If you have them please also move them to peripherals.c
Consider your 7 segments as an external peripheral device.
Let me know your findings
Best Regards
360件の閲覧回数
luis_maravilla
Could you please share your peripherals.h file and peripherals.c? Or describe how did you add the declaration for CA_LUT?
Could you please share how did you use CA_LUT in main.c?
Kindly share all the files names in which do you have [#include "peripherals.h"], are those files headers included in main.c?
Best Regards, Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2406174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%87%8D%E8%A4%87%E3%81%97%E3%81%9F%E5%A4%89%E6%95%B0%E5%AE%A3%E8%A8%80%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFLPC824%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9Flpcxpresso824max_new_project%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%80%81%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9A%E6%9C%80%E5%88%9D%E3%81%AB%E3%80%813%E6%A1%81%E3%81%AE7%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88LED%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E5%AE%A3%E8%A8%80%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81main.c%20%E3%81%AB%E6%9B%B4%E6%96%B0%E3%83%AB%E3%83%BC%E3%83%81%E3%83%B3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E6%99%82%E3%81%AB%E3%80%81%E9%87%8D%E8%A4%87%E3%81%97%E3%81%9F%E5%A4%89%E6%95%B0%E5%AE%A3%E8%A8%80%E3%81%A8%E3%81%84%E3%81%862%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%80%8C%E6%9C%AA%E5%AE%A3%E8%A8%80%E3%81%AE%E5%A4%89%E6%95%B0%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%95%B0%E5%90%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%90%8C%E3%81%98%E9%87%8D%E8%A4%87%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%BF%E3%81%B9%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E9%87%8D%E8%A4%87%E3%81%AF%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E3%81%A4%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FMCUXpressoIDE_25.6.136%2Fide%2Fplugins%2Fcom.nxp.mcuxpresso.tools.macosx_25.6.0.202501151204%2Ftools%2Fbin%2F..%2Flib%2Fgcc%2Farm-none-eabi%2F14.2.1%2F.%2F..%2F..%2F..%2Farm-none-eabi%2Fbin%2Fld%3A%20.%2Fsource%2F%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB.o%3A%2FUsers%2Fjulian%2FDocuments%2FMCUXpressoIDE_25.6.136%2Fworkspace%2Flpcxpresso824max_new_project%2FDebug%2F..%2Fsource%2F%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB.h%3A57%3A%20'CA_LUT'%E3%81%AE%E8%A4%87%E6%95%B0%E5%AE%9A%E7%BE%A9%3B%20.%2Fsource%2Fmain.o%3A%2FUsers%2Fjulian%2FDocuments%2FMCUXpressoIDE_25.6.136%2Fworkspace%2Flpcxpresso824max_new_project%2FDebug%2F..%2Fsource%2F%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB.h%3A57%3A%20%E3%81%93%E3%81%93%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Duplicate%20variable%20declarations%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3F%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81CA_LUT%E3%81%AE%E5%AE%A3%E8%A8%80%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%9F%E3%81%8B%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3Emain.c%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E4%BD%BF%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8BCA_LUT%3F%3C%2FP%3E%0A%3CP%3E%E3%81%A9%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AB%5B%23include%20%22peripherals.h%22%E3%80%91%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AFmain.c%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%E3%83%AB%E3%82%A4%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Duplicate%20variable%20declarations%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%A7CA_LUT%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%81%9D%E3%81%86%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%81%99%E3%80%82%E9%87%8D%E8%A4%87%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8C%E8%A4%87%E6%95%B0%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%80%8D%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%A3%E8%A8%80%E3%82%92%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E3%81%A0%E3%81%91%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8BCA_LUT%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E5%86%8D%E8%A9%A6%E8%A1%8C%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AB%E5%90%8C%E6%A7%98%E3%81%AE%E7%94%B3%E5%91%8A%E3%82%92%E4%BB%96%E3%81%AB%E3%82%82%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%82%82%E3%81%97%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AA%E3%82%89%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB.c%20%E3%81%AB%E3%82%82%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E7%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%A4%96%E9%83%A8%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AA%BF%E6%9F%BB%E7%B5%90%E6%9E%9C%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Duplicate%20variable%20declarations%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AE%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%82%3C%2FP%3E%3CP%3E%2F%2F%20%E6%95%B0%E5%AD%970%EF%BD%9E9%E3%81%AE%E3%83%AB%E3%83%83%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%EF%BC%880%EF%BC%9D%E3%82%AA%E3%83%B3%E3%80%811%EF%BC%9D%E3%82%AA%E3%83%95%EF%BC%89%3CBR%20%2F%3E%20const%20uint32_t%20CA_LUT%5B10%5D%20%3D%20%7B%3CBR%20%2F%3E%20%2F%2F0%3A%20A%E3%80%81B%E3%80%81C%E3%80%81D%E3%80%81E%E3%80%81F%E3%81%AF%E3%82%AA%E3%83%B3%E3%80%81G%E3%80%81DP%E3%81%AF%E3%82%AA%E3%83%95%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%201%3A%20B%E3%80%81C%E3%81%AF%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_B%3E%3C%2FSEG_B%3E%20%2F%2F%202%3A%20A%E3%80%81B%E3%80%81D%E3%80%81E%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%203%3A%20A%E3%80%81B%E3%80%81C%E3%80%81D%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%204%3A%20B%E3%80%81C%E3%80%81F%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_B%3E%3C%2FSEG_B%3E%20%2F%2F%205%3A%20A%E3%80%81C%E3%80%81D%E3%80%81F%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%206%3A%20A%E3%80%81C%E3%80%81D%E3%80%81E%E3%80%81F%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%207%3A%20A%E3%80%81B%E3%80%81C%E3%81%AF%E3%82%AA%E3%83%B3%E3%81%A7%E3%81%99%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%208%3A%20%E5%85%A8%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88ON%20(AG)%3CBR%20%2F%3E%20~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%2F%2F%209%3A%20A%E3%80%81B%E3%80%81C%E3%80%81D%E3%80%81F%E3%80%81G%E3%81%8C%E3%82%AA%E3%83%B3%3CBR%20%2F%3E~((1%26lt%3B%3CSEG_A%3E%3C%2FSEG_A%3E%20%7D%3B%3C%2FP%3E%3CP%3E%2F%2F%201%E6%A1%81%E7%9B%AE%E3%80%812%E6%A1%81%E7%9B%AE%E3%80%813%E6%A1%81%E7%9B%AE%E3%81%AB%E5%8D%B0%E5%88%B7%E3%81%95%E3%82%8C%E3%82%8B%E7%8F%BE%E5%9C%A8%E3%81%AE%E6%95%B0%E5%80%A4%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E5%A4%89%E6%95%B0%3CBR%20%2F%3Evolatile%20uint8_t%20display_buffer%5B3%5D%20%3D%20%7B1%2C%202%2C%203%7D%3B%20%2F%2F%20%E4%BE%8B%3A%20%22123%22%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%82main.c%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3A-%3C%2FP%3E%3CP%3Euint8_t%20numeric_value%20%3D%20display_buffer%5Bcurrent_digit%5D%3B%3CBR%20%2F%3E%20uint32_t%20segment_pattern%20%3D%20CA_LUT%5Bnumeric_value%5D%3B%3C%2FP%3E%3CP%3E%3CSPAN%3E%23include%20%22%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%22%20%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AE%E3%81%BF%E5%87%BA%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%3A%20-%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Emain.c%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%88%E3%81%BB%E3%81%A9%E3%82%82%E8%A8%80%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AFCodeWarrior%E3%81%8B%E3%82%89%E6%9D%A5%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%3C%2FSPAN%3E%E3%80%81MCUX%E3%81%AE%E7%9F%A5%E8%AD%98%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%8D%B1%E9%99%BA%E3%81%A7%E3%81%99(%3F%3F%3F%3F%3F)%E3%80%827%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%88%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB(peripherals.h%20)%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93c)%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%94%E3%83%B3%E6%95%B0%E3%81%AE%E5%AE%A3%E8%A8%80%20(pin_mux.h)%E3%81%9D%E3%81%97%E3%81%A6c)%E3%80%81%E3%81%A7%E3%82%82%E3%81%9D%E3%82%8C%E3%81%AF%E5%BE%8C%E3%81%A7%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
