Does LPC54628 support more than one ethernet PHY?
901 次查看
PLM
The pinout of the MCU suggests that there are enough pins to set up two ethernet PHYs. Is this possible? For example read sensor data from two ethernet based sensors without setting up an intermediate switch.
891 次查看
Hello @PLM
You can try to connect two, but, only can can used at the same time.
Alice
