Content originally posted in LPCWare by h.lotfi on Wed Jan 07 09:37:51 MST 2015
Quote: bavarian
Don't mix up Bits and Bytes  ;-)
DYCS0 supports an address range of 128MBytes, this means that you could have a 1Gbit SDRAM device.
But this range is not supported by the SDRAM controller, for a 16-bit SDRAM the MCU supports up to 512Mbit (= 64MByte) on each CS.
So don't worry, your 256Mbit SDRAM will work.
NXP Support Team
Thank you very much  ;-)
