CRC Engine on LPC54xx/S0xx
1,127件の閲覧回数
ceso
Hello, are the only compatible CRC's for the CRC engine the three CRCs that are in the datasheet? Or will additional CRCs need to be implemented by using user-developed software that will not run in the engine? Additionally, does it support 8-bit CRCs
1,109件の閲覧回数
1) "are the only compatible CRC's for the CRC engine the three CRCs that are in the datasheet? Or will additional CRCs need to be implemented by using user-developed software that will not run in the engine?"
->> YES.
2) Accept any size of data width per write: 8, 16 or 32-bit.
Alice
