About internal ROM
About internal ROM
taka01
Hello.
Does the built-in ROM cause the data to be rewritten without permission?
When a programming file is written, mounted on a board, and then inspected, a phenomenon occurs in which it is rarely rewritten and does not work.
I don't know what caused it.
Can it be caused by any settings or external factors?
ZhangJennie
LPC43 BootRom doesn't program without permission.
What tool do you use to program board? How can I reproduce your issue?
Jennie
ZhangJennie
Jennie
